I am working on MacBook 12" A1534 2017 820-00687-B assuming that the logic board is same as 820-00244-B. It was not powering on. I did a ultra sonic cleaning of the motherboard since I saw some traces of liquid spill. Tested out of the casing, all worked fine & display was working 100% well. When I installed it again, no display. So I again was removing the logic board & while removing the keyboard connector I saw little smoke off the connector. I started to check the voltages again. 3.3volts is perfect but 5 volts rail fluctuates on & off on coil L7670 (PP5V_S4)., 5V come & goes again. I did not find any short to ground on this rail. Any tips or guidance will really be appreciated. Thanks in advance.
Re: MacBook 12" A1534 2017 820-00687-B
Ok 'mon2"., on the EN1 pin of U7650 (PM_SLP_S5_L) the voltage toggles on & off, even on pin 7 & 8 same thing voltage toggles.. But EN2 (S5_PWR_EN) pin 21, here the voltage is constant 3volts, this is why I am getting the 3.3v perfectly. Next to check I think "PM_SLP_S5_L" from where it genereating or some rail. Please inform me.. ThanksComment
The CPU may be defective as reported by more seasoned techs on this forum but hate to believe it. It is a show stopper of an issue if true.
Our fancy BGA rework station should land next week and we are looking forward to complex repairs like CPU rework / reflowing. Has multiple HD vision cameras to perfectly align the balls once we clean the drop site.
2) What is the voltage on PM_SLP_S5_L ? nearly 2.9 & then drops
What is the voltage reading once this rail settles ?Comment
This was a 11" Apple laptop, you know I could not find the problem, eventually I purchase a new motherboard, got for $200, worth it. You look for a new motherboard too, very difficult to find where the problem would be. ThanksComment
by stefanbsThe laptop is Apple Macbook A1534 2017 with board 820-00687-А. The USB-C tester shows no voltage, there is 820-00244-А board available. I looked at both schematics, all connector signals seem to be the same. Did someone try to fit 820-00244-А board in A1534 2017?05-11-2025, 01:08 AM
by soflesHello there
I have problem with Macbook Pro 15" 2017, model 2017, MB code 820-00928.
I bought it as broken with some artefacts on the screen, first I thought that this is problem with ribbon cable but after inspectiing ribbon cable I know it is fine. I tried to reinstall macOs and then I figured out that this must be something with GPU as installation freezes at the end (when drivers are loaded). I installed Windows and was able to install every each of drivers except GPU driver, as soon as I tried to install GPU driver - black screen and restart.
...11-21-2024, 05:25 AM -
by CG_DionysosHello,
I am looking for the boardview file and the matching schematics (PDF) for the following MacBook Pro:- Model: A1707
- 15-inch, Mid 2017
- 3.1 GHz Core i7
- 16 GB RAM
- Radeon Pro 560
- 1 TB SSD
- Board number: 820-00928-A
Thanks in advance!
Greetings from Germany...-
09-16-2025, 06:43 AM -
by Nagy DanielHi, I'm Daniel, and I'm new to the world of repairing motherboards.
I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
So, I generated a table with AI so I can... -
by obelix24Hi All,
i got one Macbook a1534 boardnumber 820-00244 that is taking only 5V 0,2A
I've tried to replace 3x CD3215B01 chip but it's still behaving same ....
On the board there was blown L4804 so i've replaced it.
when power is connected 5V 0,2A
PPBUS_G3H - 0V
PP20V_USBC_XA_VBUS_F - 5V
I've tried to remove F7040 as mentioned here
https://www.badcaps.net/forum/troubl...1534-820-00244
but there is... - Loading...
