A2159(820-01598) no image
  • liteott
    • Mar 2012
    • 23
    • usa
    Macbook ProA2159 with board 820-01598 with black screen. was water damage. Measured lcd connector J8500 and find pin #1 (EDP_AUXCH_N) short to ground 2 ohm. Looks like it goes to U0500(CPU) directly . Is it anything to do? Starts fine and all, just no image
  • liteott
    • Mar 2012
    • 23
    • usa
    Re: A2159(820-01598) no image
    Someone say that's CPU EDP partial Damaged. can it be fixed without replace the CPU(U0500)??? need solution please.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      What’s it measure with display unplugged ?
      • piernov
        • Jan 2016
        • 4435
        • France
        Dead CPU. Backlight rail arced to eDP AUX line and killed it.
        • liteott
          • Mar 2012
          • 23
          • usa
          Diode mode 0.001 and 0.064v or 64mV on that pin#1. are there any way to rescue ? I am not able to replace the cpu or take it off to check if it is cpu dead or PCB board short.
          and is that "EDP_AUXCH_N" a power supply point or it's some data signal to activate the screen? can we use "EDP_AUXCH_P"--Pin #3(0.9V and 0.129 diode mode-- measured) to emulate it ?----sure need to cut cpu to pin #1 the trace first.
          for all your experts do you think to do this will damage more the cpu or screen I don't know how risky it will be at least use external monitor still can use this laptop and or the screen is not cheap.(if damaged)
          I am new for this hope got some advice thanks for all you guys.
          • liteott
            • Mar 2012
            • 23
            • usa
            Anyone have suggestions? thanks in advanced.
            • mon2
              • Dec 2019
              • 14086
              See post #4.
              Does this unit work with an external monitor? If possible, test with an external monitor. I know that we have done this with some external dongles to validate the position of the logic board.
              Also, we recently purchase a POST code reader for macbook and iMacs that apparently will confirm the boot cycle of the cpu. Bought from Asia but not yet used.
              That tool would help here. I think you stated earlier the logic board chimes? That is quite positive. Perhaps review your lvds connector and cable with all power off so no voltages cross onto other pins.
              Either way, you will need to know if your CPU is damaged beyond use or not.
              We are studying in how to replace large bga devices like such cpu but this will require a high quality bga rework station.
              • piernov
                • Jan 2016
                • 4435
                • France
                Everything will work except the internal display since the eDP output of the CPU is dead.
                • liteott
                  • Mar 2012
                  • 23
                  • usa
                  For Mon2 yes it works on External Monitor.
                  Still I want to know if the "EDP_AUXCH_N" is power line or it's data signal line? can it be use "EDP_AUXCH_P" emulate add to eDP LCD? or it is feedback signal from LCD to CPU and let CPU know the LCD status then CPU will activated video functions or others etc...
                  Other thing I confirm the water damaged eDP LCD screen is good After cleaned LVDS EDP Display FPC Connector the connector was burned pin#43 and pin#1 became black color. and after cleaned I use A1706(820-00923-a) mainboard(that only working board I have) to test the eDP LCD with cleaned original flat flex video cable the video image came out perfectly.
                  Now How can I rescue this no inner video image mainboard.
                  Hope experts help me out thanks.
                  • liteott
                    • Mar 2012
                    • 23
                    • usa
                    Hope you guys can help me: I bought same 820-01598 board from eBay (less than $200) try to replace that "eDP output of the CPU is dead" board but the board I bought had !"activation lock"! on it. my question is Can I just swap the SPI EEprom (U4770) to removal the "Activation lock"???
                    this board locked everything can not boot from external USB drive (secured not allowed) and tried to erase inner volume to reinstall and next boot up still there can not go in security manage utility to enable external drive boot.
                    thank you
                    • sayumin
                      • Apr 2021
                      • 7
                      • Japan
                      I have a similar board in my hand. I also think the eDP of the CPU is partial dead.
                      Is there no chance to repair it without change the CPU?
                      Thank you!
                      • duchtesciowej
                        • Apr 2016
                        • poland
                        The problem is: What about ME region after replace CPU. I was replaced CPU, board are start, but I can't open OS (ME corrupt, and just think what must to do to reset / replace the ME.) ? Just read 32mbit rom ic and have no found any signs of ME
                        Update: After replace cpu (with integrated pch) we must put Mac in dfu mode and restore the system. The ME is stored in flash memory or t2 ic. All data will be lost off course. In 15" and 16" there is no problem with ME after replace cpu.
                        • dbuergi
                          Water damaged MacBook Air A1932 AmrestoreErrorDomin Error-9 trying to restore with configurator
                          by dbuergi
                          this Macbook was stuck at 5v and didn't start because of some water damage. I was able to clean everything and the board started. So i put everything back together and the Macbook seems to boot with 20v, 1,4A and 29W. So i decided a DFU recovery. At 50% of the system repair i get the error massage from the title. Display stays black and no Apple logo. Both repair and recovery don't work.
                          Is there anything i can do?
                          11-19-2024, 09:27 AM
                        • dbuergi
                          Macbook A1466 820-00165A heavy water damage but working with "flashing" screen
                          by dbuergi
                          i got a A1466 with serious water damage. I was able to clean the whole board and only found a fuse with a coroded trace. Cleaning and resoldering did the job and the macbook started normal but after some time the screen began "flashing" like turning on and off while the Macbook was still running. I checked the board again but was not able to find the problem until now.
                          Any ideas where to look?...
                          11-07-2024, 10:57 AM
                        • Grandoni Manuel
                          MacBook a2289 water damage
                          by Grandoni Manuel
                          Hello to all ! I follow you but this is first time write !!
                          your forum is the best !!
                          so I’ve a2289 with water damage ! In first time other friend have clean and work ! But after some time stop working !
                          now, I open the MacBook and I see a lot of corrosion near backlight circuit (I attach some photos about that ) I think the problem is on backlight maybe bcs do strange boot then reboot (attach video ) I change some thing on the circuit like :
                          q8400
                          q8401
                          D8410
                          and the resistor R8431
                          if I check PPVIN SOSW LCDBKLT_R I’ve 12,9v
                          on...
                          04-03-2025, 06:45 PM
                        • envym
                          MacBook Pro 2018 with Activation Lock
                          by envym
                          Hi everyone!
                          I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
                          I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
                          06-27-2025, 08:54 AM
                        • arevut
                          Macbook Air 2020 13” model: A2337 backlight is on but no image
                          by arevut
                          Hi all! MacBook Air A2337. There are no traces of liquid or obvious damage, the motherboard is visually in perfect condition. The image is displayed on the external screen, but only the backlight works on the internal screen. There is no image, and the camera on the built-in screen does not work. How to exclude during diagnostics that it is the screen that is broken and not the motherboard? What signals should be present on the connector with the screen removed and connected?
                          02-07-2024, 08:07 AM
