MacBook Pro 16" 2019 A2141 No Power
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 674
    Hello all
    Your favorite BadCaps user here!
    I bring to you a repair we just attempted.
    Originally it was at 5V (water damage, very significant)
    I repaired the computer replaced all the bad caps and a few resistors and now the computer is finally getting to 20V
    But the amps were originally going to .28A now they are not even moving pass .11A
    So right now we have 20V and .11A into the computer.
    I checked PPBUS_G3H and its present. Pulled up power alias 1 and 2 and I am kind of dumbfounded. The voltage is present at CPU HS etc. But what gives? Check G3H rail, present. I repaired a PPBUS_G3H rail that had a pad that was removed terrible but I was able to salvage what was left of it to be able to put a CAP on it so voltage is now there. I am looking to have a point to look at where I am missing.
    Any ideas or clues?
    sigpic
    MEOWING IN THE IMPOSSIBLE UNIVERSE!
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: MacBook Pro 16" 2019 A2141 No Power
    Why not list the power rails?
    • Stephen
      Meow Meow MEOW!
      • Apr 2020
      • 674
      I am looking at Power Alias page 1 and going down the line
      PBUS and High Side is present.
      20V is present so PPBUS (aka greenlight is present)
      sigpic
      • Stephen
        Meow Meow MEOW!
        • Apr 2020
        • 674
        Also get this Piernov
        3 TB ports gets 20V
        One only gets 5.12V . I am assuming this is the culprit that is causing it to not boot
        sigpic
        • piernov
          • Jan 2016
          • 4439
          • France
          You should watch some Louis Rossmann videos.
          20V is on PPDCIN_G3H.
          PPBUS_G3H should be 12.6V
          "Green light" (not present on USB-C machines) would be dependent on PP3V42_G3H (not present on USB-C machines).
          Also there are many more power rails than this.
          • Stephen
            Meow Meow MEOW!
            • Apr 2020
            • 674
            I meant as there is no Greenlight but the 20V is present as in Greenlight visually for the USB C tester if it was a plug in DC. Sorry didn't explain that well.
            sigpic
            • Stephen
              Meow Meow MEOW!
              • Apr 2020
              • 674
              awe yes PPBUS_G3H is present at 12.6Volts sorry.
              sigpic
              • Stephen
                Meow Meow MEOW!
                • Apr 2020
                • 674
                Figured it out! It was the 5Volt area preventing the computer from booting.
                sigpic
                • tech_guru
                  Macbook Pro 2019 A2141 NAND Shorted
                  by tech_guru
                  Hello. If you could please help me understand what I am doing wrong...
                  This model, Macbook Pro 2019 16" A2141, 512GB, EMC 3347, with T2 Security Chip, had 4 NAND Chips shorted in 1 wing (U9100, U9200, U9300, U9400) and it has 1 more in the 2nd wing (U8600) BUT NOT shorted. All chips are TSB4227 TOSHIBA-KIOXIA SN4192TWNA12014 BGA110 128GB. I got 4 new nand chips for 1 wing and programmed them by specific position of course with JCID P13 programmer.
                  I also replaced the tps power ic for the ssd.
                  Now all rails come up, including the ssd rails 0.9v, 1.8v, 2.5v....
                  08-28-2025, 08:04 AM
                • cheebster
                  MacBook Pro 2019 A2141 820-01700 NAND Issue Stuck in DFU
                  by cheebster
                  Ok, here's an issue ive got on a A2141 820-01700 MBP 16' 2019. No signs of life, 5.06v 0.0a on usb-c meter, on each 4 usb-c ports.
                  Nand voltages are missing.
                  I've found no shorts at all so far, no signs of heat via thermal camera either.
                  PPBUS_G3H 12.31
                  PP3V3_G3H_RTC 3.387v
                  PP3V3_G3H 12.31v
                  PP2v5_NAND_SSD0 0v 58 ohms
                  PP2v5_NAND_SSD1 0v 57.8 ohms
                  PP1v8_SLPS2R 1.8v
                  PP1v1_SLPS2R 1.1v
                  P3V3_G3H_SOCPMU 3.37v
                  PP0V9_SLPDDR 0.9v...
                  10-11-2023, 11:31 AM
                • tomtom67
                  MacBook Pro 16" (2019) A2141: power consumption? Dead GPU? MacOS not installing
                  by tomtom67
                  A friend brought his fresh-from-ebay macbook pro A2141 after he failed replacement keyboard plugging.
                  I fixed all the little problems he introduced.
                  I am unable to install macOS to this device. Both Sequoia and Catalina (from Internet Recovery) start to install, but after ~2-5 minutes into the installation the macbook does a hard restart (max fan spin for a split second, then reboot without chime).
                  I noticed what I think is a very high power consumption, like 20V/1.7A when activating WiFi for internet recovery, and more like 20V/3.7-4.1A while downloading the recovery...
                  10-08-2024, 08:59 AM
                • rathore4u
                  Macbook Pro 2019 16" A2141 820-01700 stuk in DFU mode
                  by rathore4u
                  I am trying to fix a T2 Macbook A2141 820-01700 board that's stuck in DFU mode.
                  The SSDs have correct voltages
                  PP2V5_NAND_SSD0 = 2.5V
                  PP2V5_NAND_SSD1 = 2.5V
                  PP0V9_SSD0 and PP0V9_SSD 1 = 0.9V
                  PP1V8_SSD0 and PP1V8_SSD1 = 1.8V
                  I can force the laptop to DFU mode using the SOC_FORCE_DFU using SWK003. Apple Configurator 2 tries to restore the Mac but it fails back to RECOVERY.
                  Looking at the diagram here - https://repair.wiki/w/Apple_T2_platform Step 6, it says the problem could be loading from SSD,...
                  02-23-2025, 09:16 AM
                • ApplePie14
                  MacBook Pro 2019 16inch A2141 no power
                  by ApplePie14
                  My Macbook, which had been working fine until two weeks ago, now has unstable power and won't turn on.
                  When I took it apart, I found a lot of dust, so I think that might be what caused the damage.
                  I checked with a USB meter and found that the voltage is 20V, and the current consumes a maximum of about 150mA, then fluctuates between 4 and 70mA.
                  The same thing happens when the battery is removed.
                  There were no short circuits in the PPBUS_G3H or NAND.
                  08-25-2025, 12:17 AM
