Toshiba Satellite - Locks up when plugged in
+ More Options
Posts
  • redw00d
    • Jul 2011
    #61
    Re: Toshiba Satellite - Locks up when plugged in
    sorry master to my previous post.
    I've just open my toshiba m200 laptop and under the CPU is the NEC/TOKIN 0E128 (1200UF). Just wanna ask what type of capacitor could I subtitute? how many capacitors? and the rating of each capacitor.. thanks in advance.
    • incradibles
      • Feb 2011
      • 43
      #62
      this technique worked for me thanks
      Silence Like Dreams
      • benmah
        • Aug 2011
        • 6
        #63
        I have nec tokin Oe128 replaced with 4x 330e75 tantalum cap (i believe it a 330uf 2.5V cap). It works perfectly without fail after one yrs but I think it has cause my build-in multi card not to work any more from the beginning. Then I replace it with the orignal nec tokin 0e128. It still works but 2 month till now it starts to show sign of failing. It happen few days ago 3 times cut off suddenly. Now I plan to put back the 4 x 330e75 cap. Don't waste time on the 0e128 cap as it is not durable. I believe it has a 5000hrs life span on a ideal condition from the datasheet. Take a look at the pic. I use only a normal soldering gun. I just break the 0e128 with a test pen and small long nose pliers carefully. Clean up the contacts. Then carefully solder. Hope this helps U guys out there.
        • seraniko
          • Sep 2009
          #64
          thanks to this forum i finally fixed my toshiba l300. for raplacement caps here is one of my reference.
          • Volkymaniac
            • Jun 2011
            • 9
            #65
            Hi benmah; I'm trying to take out that 0e128 supercap, but it's very hard. How do you take out that??? I have the 330uf caps ready.
            • redw00d
              • Jul 2011
              #66
              thanks for the information bro. All i want to do now is to remove the supercap and find a tantalum capacitor.
              • fabiog
                • Jul 2011
                • 102
                #67
                So will it work with caps higher than 2.5 eg 6v.
                • PVH
                  • Aug 2011
                  • 11
                  #68
                  E ai irmao, ablacon64?
                  Where can I find these caps (the four replacement you used) in Brasil? Can you send me an address or phone where I can buy/order those? Valeu...
                  • fabiog
                    • Jul 2011
                    • 102
                    #69
                    I just made my satellite work with 4x 330 4v caps and a 60w soldering iron lol.
                    Thanks for all the help
                    • Thedead
                      • Sep 2011
                      • 13
                      #70
                      I fixed one toshiba satelite using 4x 330e71 it working fine now. One more to go.
                      • zmec
                        • Aug 2011
                        #71
                        Hello everybody, nice forum!
                        Has anybody tested NEC/Tokin OE128 in circuit?
                        What readings did you get?
                        I tested it and got C = 1770uF ESR = 0.00 ohm
                        I am confused.
                        Is it faulty or not?
                        (A200 Restarts and will not boot successfully when connected to AC, on battery it works ok)
                        • wmbuddhi
                          • Sep 2011
                          #72
                          Originally posted by ablacon64
                          I had the opportunity to solve another one with that same problem, this time I took some pictures. Hope it helps.
                          The notebook is a Toshiba Satellite A305-S6872.
                          The first image shows the capacitor removed, board cleaned.
                          The second, new solder added to the pads.
                          And finally, the finished job.
                          Can i use higher voltage tantalum capacitors for the above solution? (like 10 v) ?
                          • ablacon64
                            • Jan 2011
                            • 89
                            #73
                            No problem.
                            • riget
                              • Sep 2011
                              • 66
                              I had a Tosiba with the same fault, I removed the nec/tokin oe128, fitted 4x330 e51's removed from a scrap board and it's working fine.
                              Thanks.
                              • manuel76
                                • Sep 2011
                                #75
                                Hi sir/s, is there any other replacement value for 330uf with 2.5v? can I use a higher value instead? TIA
                                • benmah
                                  • Aug 2011
                                  • 6
                                  #76
                                  Hi redwood,
                                  Sorry I was not following the thread. If it's not too late. As I have said I just use a test pen or screw driver and pry it off the motherboard carefully and clean the contact with the solder iron(prefer a higher wattage solder iron). It sound crude but you have no way of removing it with a standard solder iron. This is my only way.
                                  • benmah
                                    • Aug 2011
                                    • 6
                                    #77
                                    I am confused.
                                    Don't waste your time on this useless and not durable capacitor. Your problem is definetely the 0e128 stupid cap. After replacing it only lasted 3 month and back comes the same thing. Just replace it with the 330e71 tantalum cap 4 pcs.
                                    • benmah
                                      • Aug 2011
                                      • 6
                                      #78
                                      The 0E128 is 1200uF. So 330uF x 4 =1320uF. I would not risk going any higher value. You can use a higher voltage cap though but not too high..Keep the value within range of +-1200uF
                                      • ablacon64
                                        • Jan 2011
                                        • 89
                                        #79
                                        Make it a little higher, never a little lower.
                                        • wmbuddhi
                                          • Sep 2011
                                          #80
                                          Was this having nec/tokin OE128 OR 907 previously? Is it ok to solder 4x 330u s for a board having a OE907 originally because its capacitance is 900u right?
                                          please help
                                            Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro A40-C-1P5 boardview and Satellite Pro A40-C-1P5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 06:10 AM
                                            Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro R50-C-17C boardview and Satellite Pro R50-C-17C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 05:40 AM
                                            09-06-2024, 05:27 AM
                                            Toshiba Satellite Satellite P50t-C-111 Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Satellite P50t-C-111 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite P50t-C-111 boardview and Satellite P50t-C-111 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-06-2024, 08:10 PM
