Toshiba Satellite - Locks up when plugged in
  • will2013
    • Oct 2014
    Re: Toshiba Satellite - Locks up when plugged in
    Quick Q, What should I do if in the removal process of the TOKIN, I have exposed copper in the centre? Is it possible to still earth to the - pads? General advice etc would be good. Thank you muchly.
    • tw2005
      • Oct 2011
      • 6458
      Check out post#732
      that's genius, you won't have to fiddle trying to squeeze them in on an angle to solder to the original tracks.
      Bad picture though, so you have 3 tracks, thin sections at either end and a large common track in the middle. So long the tracks are not shorted to one another, looks messy in the photo.
      I'd just clean and tin those up and put the caps in
      • rievax_60
        • May 2012
        • 897
        • australia
        #743
        You might be heading down the same rails as the guy in the this thread, https://www.badcaps.net/forum/showthread.php?t=40103
        Try to not make the same mistakes.
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3591
          • slovakia
          #744
          just separate side rails to be not shorted with middle rail and u r good to solder 4x 330d capacitors
          • magneh
            • Apr 2014
            • 588
            • Portugal
            #745
            Ahah My Thread!
            That board is still in my office, on the SCRAP box lol
            Got another one with same NEC/tokin issue for 10$ and fixed it.
            That one was just one practical lesson of "how NOT to do it"...
            Hope you read it well and use it for not making the same noob mistakes I did.
            Good Luck!
            • goodpsusearch
              • Oct 2009
              • 2850
              • Greece
              #746
              So you couldn't recover it in the end?
              • will2013
                • Oct 2014
                Sorry for the bad photo, i will try to post clearer. I haven't soldered anything that is how the board was. I understand that there is - pads however if the copper is just an earth then it should still function (?). I haven't applied anything to the board it is just as it was removed (too heavy handed), mistakenly thinking that i had not yet removed the whole of the chip.
                Thank you for the tips, ill try to clean it up and see how and if I go/don't go. The thing cost me nothing anyway so good place to learn.
                Just reading on general things before I go further as this is my first try at any finer electronics. Once again, Thanks alot for replies!
                • gailenjensen
                  • Nov 2014
                  FYI for all in at least this thread. I read this entire thread because I was having the very issue that was in post #1. After reading it, I found on Ebay a source in southern California, about 75 miles from me, that has in the description "Toshiba laptop Repair" describing the caps. So far after installing them, it will boot up on ac power and stay running on ac power.
                  Very Big Thanks To All!!!
                  • bluecatfish
                    • 20
                    Thanks to all for the good info in this thread. I have read it from start to finish. I have A205-S7468 with the restart problem. I have removed the OE128 Tokin and have lifted 4 NEX dN8 chips from a salvage board. Before I solder them on my question for the experts is the voltage and ESR okay. I believe they are 330uF but I have not been able to determine the voltage. Any advice appreciated. Thanks.
                    • bluecatfish
                      • 20
                      Soldered the NEX dN8 chips on the board and reassembled the laptop. Power light, battery light on and fan runs but no post. Chips may not be right or bad. Am ordering new T520V337M2R5ATE009 chips to put on board.
                      • 1vica
                        • Dec 2014
                        • croatia
                        #751
                        Hi there,
                        I have repleace nec tokin oe128 with new one orderd from ebay, with old one, laptop (satellite l350) was reebooting while trying to load windows on charger, working fine only on battery. But, with new tokin capacitor it is not booting at all, fan just spinning, no beeps, no nothing else. Before touching old tokin, I have remove CPU, RAM, HDD, disconnect all connectors, scrach down old tokin with very sharp iron solder end, didnt damage MBO, and connect new tokin with wires to MBO (wire length each cca 2cm). If I turn on laptop without CPU, fan spins for 30 sec, then laptop shuts down, with mounted CPU fan just spins, no shutdown, no bios, no nothing...
                        What is dead, CPU or motherboard? Is it posible that new tokin is faulty? How to check it?
                        How should laptop work (for testing only) if I try to start it without tokin capacitor?
                        I was very carefull with taking old tokin out, and with soldering new one in, thats why I dont understand why and what is wrong, or what am I missing???
                        Big thanks for replay, help me figure this out, cose I have no more idea what to do...
                        • rievax_60
                          • May 2012
                          • 897
                          • australia
                          #752
                          It wont work when it's connected with wires. It is very difficult to properly solder the nec/tokin capacitor. Use tantalum capacitors like everyone else.
                          • 1vica
                            • Dec 2014
                            • croatia
                            #753
                            OK, I will find some (as described in previous posts) and give it a try... Thx for advice!
                            • rievax_60
                              • May 2012
                              • 897
                              • australia
                              #754
                              Also read more of this thread to find the mistakes made by others.
                              • Dalgacı12
                                • Oct 2014
                                • Türkiye
                                #755
                                make important business and use low ESR capasit clean, read instructions carefully.
                                • 1vica
                                  • Dec 2014
                                  • croatia
                                  #756
                                  Thank you guys so much!!!
                                  Instead of connecting tokin with wires, I throw away tokin oe128 bought on ebay for 0,99$, and take few capacitors form old (definitely dead MBO), and I soldered them straigth on MBO (like rievax_60 advised me).
                                  3x220 on one side and 2x330 on other side, put it back together, and.....
                                  IT IS WORKING!!! THANK YOU!
                                  On pictures you can see how I soldered oe128 (still do`nt understand why it did`nt work, and how those less then 1" wires mess it up...), and on other picture is shown how I solderd capacitors, the working solution (this is the worse looking solder joint I ever did, but it is working...)!
                                  Once again, thank for advice!
                                  • rievax_60
                                    • May 2012
                                    • 897
                                    • australia
                                    #757
                                    The Vcore supply to the CPU is low voltage high current. Very roughly ~1V and upto ~20. The CPU can go from drawing low current to high current in a very short time, less than 1 microsecond. The long wires add too much series inductance to the capacitor which allows the voltage to dip when the current suddenly increases. The CPU then crashes.
                                    For the same reasons, any replacement capacitors need to have a low ESR rating. No one knows how low, the lower the better. I use 2R5TPE330M9, which are 9 milliohms.
                                    • rievax_60
                                      • May 2012
                                      • 897
                                      • australia
                                      #758
                                      That first line should have looked like this, The Vcore supply to the CPU is low voltage high current. Very roughly ~1V and upto ~20A.
                                      • Dalgacı12
                                        • Oct 2014
                                        • Türkiye
                                        #759
                                        Use a minimum of 60 watt soldering iron,
                                        • Jeferson
                                          • Dec 2014
                                          • Philippines
                                          #760
                                          A million thanks guys
                                          2 Laptops brought back to life!
                                          Toshiba Satellite L300 which is >>1 year dead given to me by my sister in Canada (due to this shutdown problem)
                                          Acer Aspire 4736Z
                                          At last I've found a site for learners like me.
                                          Thanks again.
                                            Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro A40-C-1P5 boardview and Satellite Pro A40-C-1P5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 06:10 AM
                                            Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro R50-C-17C boardview and Satellite Pro R50-C-17C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 05:40 AM
                                            09-06-2024, 05:27 AM
                                            Toshiba Satellite Pro Satellite Pro R50-EC-12X Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Pro Satellite Pro R50-EC-12X Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro R50-EC-12X boardview and Satellite Pro R50-EC-12X schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            09-06-2024, 08:10 PM
