Toshiba L300 Image Issues when entering OS
  • magneh
    • Apr 2014
    • 606
    • Portugal
    Hello!
    I've got a toshiba L300 with this graphics issues when entering windows.
    See photos attached.
    Does anyone knows what causes this issue?
    Bad GPU?
    Bad cpu vcc?
    The laptop boots normally with no graphics issues till entering windows. In bios etc image is OK. Third photo is when connected to external monitor.
    Thanks!
  • rievax_60
    • May 2012
    • 897
    • australia
    Re: Toshiba L300 Image Issues when entering OS
    It might be the CPU Vcore capacitor problem. Does it work ok on battery only power?
    • magneh
      • Apr 2014
      • 606
      • Portugal
      I got the laptop without battery...
      I cant test without DC adapter.
      NEc tokin issue here?
      Thanks!
      • senchire
        • Dec 2012
        • 190
        • Bosnia
        Not same series nor maker but have currently the Dell inspirion 8500 which gets random artifacts (same like yours) in my case the GPU needed a reflow.
        • thodoris10
          • Mar 2014
          • 16
          • Greece
          Replace the NECTOKIN capacitor, i had issues like this with similar toshiba L300.
          • rievax_60
            • May 2012
            • 897
            • australia
            Let us know what you are doing before each step. There is a lot to know and the other thread is very large now.
            https://www.badcaps.net/forum/showth...315#post437315
            https://www.badcaps.net/forum/showth...160#post422160
            https://www.badcaps.net/forum/showth...991#post404991
            • Djosla
              • Dec 2012
              • 246
              • Montenegro
              i think that this is typical gpu failure...
              • magneh
                • Apr 2014
                • 606
                • Portugal
                Hum...
                Any way to test if it's Nek Tokin or GPU issue ?
                Cheers!
                • rievax_60
                  • May 2012
                  • 897
                  • australia
                  I use an oscilloscope to check for ripple on the Vcore rail.
                  Or try it on battery if you can borrow one. Also see how far it gets in safe mode.
                  • alihomee
                    • Dec 2012
                    • 1582
                    • malaysia
                    just change that big caps every thing will be good..............................i done more then 70 times
                    • magneh
                      • Apr 2014
                      • 606
                      • Portugal
                      Ehehe aren't you fed up allready ?? 70?? omg
                      With same symptoms?
                      Cheers!
                      • alihomee
                        • Dec 2012
                        • 1582
                        • malaysia
                        its my daily job playing with mobos and for every single unit getting money.......
                        • magneh
                          • Apr 2014
                          • 606
                          • Portugal
                          Well got some caps to change the Nec Tokin and started by removing the original one.
                          The old capacitor was shred up during the removal, but he's no longer needed
                          Tried to clean up the pads and to put some solder on it , but it's impossible!
                          Tried to rienforce it and I think I made it worse!
                          And solder does not stick to it!
                          I made some soldering and I never got this problem...
                          Hope that this mess hasn't "killed" the Mobo...
                          I'll put some pics and i'll wait for your thoughs.
                          Cheers!
                          • senchire
                            • Dec 2012
                            • 190
                            • Bosnia
                            O.o with what did you remove that one with a knife xD?
                            • magneh
                              • Apr 2014
                              • 606
                              • Portugal
                              screwdriver and reballing tool
                              • rievax_60
                                • May 2012
                                • 897
                                • australia
                                I think your iron is too small. Did you look at the links in my earlier post?
                                • Th3_uN1Qu3
                                  Believe in
                                  • Jul 2010
                                  • 6031
                                  • Romania
                                  Same here. The board looks just fine, and you should be able to attach the capacitors to it. You need at least a 60W iron to do the job though.
                                  A working TV? How boring!
                                  • magneh
                                    • Apr 2014
                                    • 606
                                    • Portugal
                                    Hello!
                                    Thanks for the reply guys!
                                    I just mesured continuity with DMM between all 4 stripes of contact, and the are all shorted ...
                                    I've set the iron in the 450ºC and still I couldnt melt the solder in the pads.
                                    Dead mobo? :/
                                    • rievax_60
                                      • May 2012
                                      • 897
                                      • australia
                                      Originally posted by magneh
                                      Hello!
                                      Dead mobo? :/
                                      You could be measuring the CPU resistance, about 5 ohms.
                                      Try removing the CPU and testing again.
                                      There is much more to soldering than the temperature setting. Did you look at the links in my earlier post? I need to know how much notice you take of information that you are given.
                                      • c_hegge
                                        • Sep 2009
                                        • 5219
                                        I've set the iron in the 450ºC and still I couldn't melt the solder in the pads.
                                        Dead mobo? :/
                                        How many watts is your iron? The large copper ground planes on motherboards will draw the heat away from the iron, and, if it's lower wattage, it may not be able to maintain 450ºC.
                                          Toshiba Satellite Pro L300-156 Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro L300-156 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L300-156 boardview and L300-156 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                                          09-06-2024, 05:27 AM
                                          Toshiba Satellite L635-10K Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite L635-10K Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L635-10K boardview and L635-10K schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
                                          09-06-2024, 05:59 AM
