Toshiba Satellite - Locks up when plugged in
  • wise_mykl98
    • Jun 2013
    • 5
    • Philippines
    #521
    Re: Toshiba Satellite - Locks up when plugged in
    I also solder and desolder the tantalum caps forgeting to remove the power adaptor..now the charging indicator wont light up even if the power adaptor is inserted.i also made damage on the positive terminal in the pcb.do you have schematic so i could check the voltages in the motherboard..I dont know where to check...
    • spleenharvester
      • Mar 2010
      • 921
      It should still power up/charge etc if it's in the same place as the Tokin on the Satellites. I made a complete mess of my first attempt and managed to make shorts across on both sides, and it still powered up (but obviously no POST)
      So the damage must be elsewhere.
      Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
      • wise_mykl98
        • Jun 2013
        • 5
        • Philippines
        #523
        the laptop is still powering up.when i press the power button.the power led and sleep led light up and sometime the wifi led light up..the lcd backlight also light up..but no image or even text in the lcd.only black screen with backlight light up..the nvidia graphic chip get a little warm, maybe it is working..but the cpu remains cold..what can i do to fix it?please help me.
        • wise_mykl98
          • Jun 2013
          • 5
          • Philippines
          #524
          the tokin chip is located at the back of the cpu
          i want to know sir..what is best..high ESR or low ESR.. I have noticed that before i remove the nec tokin Cap.I place a unknown value capacitor on the edge of the tokin chip..which is low ESR..I confirmed it using multi tester. can you teach me sir where i should test/or put my voltmeter probe to check for vcore voltage..i only know basic electronics
          • wise_mykl98
            • Jun 2013
            • 5
            • Philippines
            #525
            how did you fixed your laptop sir?
            I think that is the problem i am facing now.it powers up but no display
            • spleenharvester
              • Mar 2010
              • 921
              That sounds exactly like what mine did with the CPU removed. You need caps ideally of ESR <10mOhms (0.01ohm), of same or greater voltage and similar capacitance.
              Get a multimeter and check for a short between both sides of the caps. Have you got a picture of it at all? I'll get one up later to show you where to test for shorts etc.
              Mine did the same and it was just a poor soldering job on the tantalums.
              Cheers
              • spleenharvester
                • Mar 2010
                • 921
                Also, anyone know why the caps have to be 2.5v and not 2v when there only seems to be 1.2v across them?..
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  #528
                  2v caps will work as well.
                  A working TV? How boring!
                  • spleenharvester
                    • Mar 2010
                    • 921
                    Oh damn I wish I knew that earlier lol. I have tons of those low ESR 2v caps from scrapped AMD boards!
                    • tapasxplore
                      • Jun 2013
                      • India
                      #530
                      Thanks all people i have soldered my Toshiba A200 with right caps,
                      two 470uF. I have ordered them from in.rsdelivers.com [India].
                      737-2832
                      Just using a small knife i removed top layers of TEC TOKIN 0E907 without using anything else. I can't remove last layer as it was soldered to the PCB , and i put SMD 470uF caps on the conductive layer using 40 W solder iron.
                      Any more Q can contact on tapasxplore@gmail.com . Will be pleased to Help you.
                      View my attached file.
                      • 68pishta
                        • Jan 2012
                        • 29
                        #531
                        I think i stuffed mine. I installed 4 360 caps across the stripe but i used regular cylindrical caps instead on a whim (already replaced with a cheap A105) and i got jack. Power but no backlight, but i did get fan but no heat off of cpu. Another thing i noticed whih doesnt sound right is i now have continuity across all terminals prior to cap install. I thought a while ago i tested them and found they were isolated? I used a large iron and solder wick to remove 99 of the old solder looking for a bridge but i didnt see any even under a scope. Any clues? Couldnt find smt tant caps anywhere locally and the ones i tried to farm off mobos broke before i could use them when i tried to remove them. I know the center pad is common to the inner stripes but the outers were isolated at one time, no other mods.....
                        • rievax_60
                          • May 2012
                          • 897
                          • australia
                          #532
                          If the CPU is still in the socket, its normal to measure a few ohms on the Vcore rail.
                          Not many types of capacitors are suitable. They have to be surface mount and very low ESR.
                          Although its long, try to read more of this thread.
                          The inner square is ground. The outer strips are connected together and is the Vcore + rail.
                          • 68pishta
                            • Jan 2012
                            • 29
                            #533
                            Cool, i read the entire 23 pages but didnt see anything about the continuity. Smt's will get tried next...anyone in usa got a few spares to sell me?
                            • spleenharvester
                              • Mar 2010
                              • 921
                              That's what happened to mine when I bridged/shorted it on my first repair. Also showed as 0v across the caps.
                              All I had to do was remove it, clean it up, and resolder - that board has been working ever since.
                              Eitherway I will be repairing my fourth one soon (and this time will use 2.0v caps, to anyone interested in trying the same). If you want me to take any readings during repair I can - but I only have a simple DMM. To be honest though, if no continuity showed before, there's a chance something else in the power chain is damaged.
                              Cheers!
                              • 68pishta
                                • Jan 2012
                                • 29
                                #535
                                That would be great if you could test continuity between center neg and outer pos with and without the cpu installed. I read that you may see 5 ohm across if cpu is installed but isolated without. Looking forward to your findings.
                                • kahodges
                                  • Jul 2013
                                  • US
                                  #536
                                  I have come across a Toshiba Satellite P205D that exhibits the very same issues as described in this thread. It will boot up fine on battery. As soon as you plug in the charger, it either blue screens or goes to black screen and freezes. It will do it randomly without the battery installed, running on just the power brick. The power brick is good. Tested with a different charger and still the same problem. I will tear the unit down and look at the caps on the motherboard. If anyone else has already been through this with the same board, assistance would be highly appreciated.
                                  • ajimetro
                                    • Aug 2013
                                    • 6
                                    • Colombo
                                    #537
                                    Wow ,Great job,& I learn lots of things here.
                                    Thanks team....
                                    • HairyManBack
                                      • Dec 2012
                                      • 32
                                      • United States of America
                                      #538
                                      Hi Guy's
                                      I happen to have the same problem with a Toshiba A205. It has the 0E128 NEC on it. Ive been looking for some capacitors that would work. I haven't found any for the life of me. If someone could send me a link to what I need it would be much appriciated.
                                      Thanks,
                                      HairyManBack
                                      • Th3_uN1Qu3
                                        Believe in
                                        • Jul 2010
                                        • 6031
                                        #539
                                        You can scavenge some off other boards. 4x 330uF 2.5v or 2v tantalum generally do the trick. Anyway... What parts supplier do you prefer? I'll try to locate some if you want to buy new.
                                        • HairyManBack
                                          • Dec 2012
                                          • 32
                                          #540
                                          I usually use Mouser, but DigiKey will work also.
                                            Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro A40-C-1P5 boardview and Satellite Pro A40-C-1P5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 06:10 AM
                                            Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro R50-C-17C boardview and Satellite Pro R50-C-17C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 05:40 AM
                                            09-06-2024, 05:27 AM
                                            Toshiba Satellite Satellite P50t-C-111 Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Satellite P50t-C-111 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite P50t-C-111 boardview and Satellite P50t-C-111 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-06-2024, 08:10 PM
