Toshiba Satellite - Locks up when plugged in
Re: Toshiba Satellite - Locks up when plugged in
I ask because, even when you guys install caps, some of you say the problem is not fixed. so I am just getting a clear idea here. well, I know its never too good to turn on something without its pieces...Comment
what i have done so far is to remove the SuperCap ( NECTOKIN) and Solder 4 330uF Tantalum Caps to where the NECTOKIN was. U will need to carefully scratch the UV coat.
i have done more then 30 laptops with the NECTOKIN in the last 6 months and all worked well.Comment
a have a problem with my client toshiba blackout with intermittent power.
Ive already replaced 4 330uf same problem
2 330uf same problem
2 220uf same problem
2 220 and 2 330 same problem
check the lan because it was blinking upon pressing the power button
remove the controller ic of the lan
but still same problem after I on the unit shutoff no display or what
ive noticed that the proc is not heating up
tried new proc same problem
any ideas sir/mam?
ive also noticed that the nothbridge was over reheated by other tech that handled this first
pls help me on thisLast edited by johnwafu; 08-27-2012, 05:42 PM.Comment
My friend have Satellite L200 that cannot boot. No post. Battery already depleted. When I plug in the power, the charging led and wireless led will automatically light up. When I pressed power button/switch, it charging led,wireless led,power led and hdd led will light up for 4-6 sec then after that only the charging led and wireless led remain light on. I already changed the NEC/TOKIN OE128. What could be the problems? I'm thinking there is shorting else where but I don't know how to look/find for it. Any help gentleman??Comment
Hi Newtonkh
Can you tell us what the Esr was, on your suggested Tantalum Caps
ThxsComment
i have found the following which may help
where for Capacitance e.g. 128=1200uF
First two digits represent significant figures.
Third digit specifies number of zeros to follow.Comment
Apparently there is not much info available about OE687 on the Internet.
OE687 refers to a capacitance of 68 followed by 7 zeros in picofarads (i.e., 680000000pF), which is 680uF (microfarads). These Proadlizers usually have ESR of between 1 to 2mΩ. Therefore, you should consider replacing it with four caps of the type T520V227M004ATE006 or similar.Comment
thanks NotsosureApparently there is not much info available about OE687 on the Internet.
OE687 refers to a capacitance of 68 followed by 7 zeros in Pico Faraday (i.e., 680000000pF), which is 680uF. These Proadlizers usually have ESR of between 1 to 2mΩ. Therefore, you should consider replacing it with four caps of the type T520V227M004ATE006 or similar.
i did find this datasheet on the oe687 (PSGD0E687M7)
http://www.datasheetarchive.com/PSGD...datasheet.html
the mouser item T520V227M004ATE006 seems to have a min buy of 320 units on a roll.
could i sub the RS 470's and exceed the uF rating by nearly double or use multiple 100uF caps?
i'm in bris australiaComment
The datasheet appears to be for small caps and I thought you have a large cap (i.e., Proadlizer) in your laptop?
If you do not want to experiment much then 7 or 8 of 100uF ceramic caps might be the easiest way to go. If you do not mind experimenting then you could try 2 or 3 of RS Stock No. 737-2832 or similar. 3 will give a total of 1410uF which is around twice the present capacitance.Comment
thanks Notsosure, sorry about the datasheet, i'm not into board level stuff. it is a proadilizer. with the 100uf ceramics how is the ESR calculated or doesn't it relate to them?The datasheet appears to be for small caps and I thought you have a large cap (i.e., Proadlizer) in your laptop?
Their ESR is probably 1mΩ so it is not a concern at all but their temp limit appears to be 85C, which too is usually not a problem unless laptop runs very hot for some reason:
http://translate.google.com.au/trans...ed=0CG8Q7gEwBgComment
thanks again Notsosure. i'm going to try the tantalums because they are easy to get`from RS. its pretty hard to source any of the other options.Their ESR is probably 1mΩ so it is not a concern at all but their temp limit appears to be 85C, which too is usually not a problem unless laptop runs very hot for some reason:
i really appreciate you taking the time to post advice here and in the many other posts i've seen here and elsewhere.Comment
You can actually get 10 of GRM31CR60J107ME39L from RS for $17 delivered, if you wish to. Of course, if you are willing to experiment with other caps then any inputs from you might help others. The choice is yours.Comment
thanks Notsosure, i didn't think of searching by the part #. i will order them today.Comment
This specification for the Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro A40-C-1P5 boardview and Satellite Pro A40-C-1P5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...09-06-2024, 06:10 AM
This specification for the Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro R50-C-17C boardview and Satellite Pro R50-C-17C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...09-06-2024, 05:40 AM
This specification for the Toshiba Satellite Pro C660-1NQ can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the C660-1NQ boardview and C660-1NQ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...09-06-2024, 05:27 AM
This specification for the Toshiba Satellite Pro Satellite Pro R50-EC-11J Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro R50-EC-11J boardview and Satellite Pro R50-EC-11J schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...09-06-2024, 08:10 PM
- Loading...
