macbook pro 820-2850 power cycle
  • protocold
    • May 2019
    • 24
    I have a macbook pro A1286 2010 820-2850 logic board that power cycles every 5s. I can see from the PSU that it is drawing about 1A and then power cycle.
    ALL_SYS_PWRGD cycles with it between 0v and 3.3v
    PPVCORE_S0_CPU cycles between 0 and 1.1v
    PLT_RESET_L is cycling between 0 - 1v
    Is this fixable?
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: macbook pro 820-2850 power cycle
    History? C9560 replaced? BIOS flashed?
    • protocold
      • May 2019
      • 24
      board seems clean with no prior repair attempt, no dirty marks.
      C9560 replaced and bios flashed, still the same.
      • piernov
        • Jan 2016
        • 4439
        • France
        Same in SMC bypass mode?
        Check voltage and resistance to ground on the GPU power rails.
        • protocold
          • May 2019
          • 24
          yes same in SMC bypass. In SMC bypass, fan spin high but still on and off pattern.
          • protocold
            • May 2019
            • 24
            PP1V05_S0GPU 0-1.04v pulses 295 ohm to ground
            PP3V3_S0GPU 0-3.3v pulses 880 ohm to ground
            PPVCORE_GPU 0-0.9v pulses 2.5 ohm to ground
            PP1V8R1V55_S0GPU_ISNS_R 0-1.55v pulses 90ohm to ground
            • protocold
              • May 2019
              • 24
              @piernov what should i do next?
              • magneh
                • Apr 2014
                • 616
                • Portugal
                Maybe check all the current sensing circuitry
                could cause the shutdown
                • protocold
                  • May 2019
                  • 24
                  thanks for your input, but could you possibly elaborate a bit as in where and where exactly i should look? I am a noob....
                  • protocold
                    • May 2019
                    • 24
                    Are you referring to the sensing circuit around ISL6259 (U7000) ??
                    pin 3 = 4v
                    pin 14 = 3.3v
                    pin 27-28 = 20.8ohm
                    pin 17-18 = 3.3ohm
                    • envym
                      by envym
                      Hi everyone!
                      06-27-2025, 08:54 AM
                    • durchfall
                      MacBook 2011 A1286 power cycle, no chime
                      by durchfall
                      I have a MacBook Pro 15" late 2011, it has a dead GPU and was sent to a repair center for this issue multiple times, the last time the original owner of this machine decided to not fix it anymore. The repair center returned the machine, but they desoldered the GPU and VRAM, it just physically isn't there anymore. The machine did originally work, we'll get to it.
                      What it does now: does not turn on in SMC bypass mode, the fans just twitch and I can hear a ticking sound from the board, almost like there was a short circuit. But in normal mode it does start, fans spin for about 10 seconds,...
                      01-11-2023, 05:56 AM
                    • Flasman90
                      Macbook Pro DFU Restore Issues
                      by Flasman90
                      I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
                      - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
                      - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
                      08-30-2025, 10:27 AM
                    • tobeend
                      Bypass mdm macbook m2 ventura
                      by tobeend
                      1. RESET MACOS WITH IPSW
                      a. Power off MacBook, press and hold the power button to enter Recovery
                      b. Open Disk Utility, remove Macintosh HD
                      c. Reboot, connect to the network to Activate Mac.
                      d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
                      d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
                      e. Release the other keys, but keep holding the Power key for another 10 seconds
                      f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
                      05-26-2023, 07:18 AM
                    • SarcasticOP
                      General question about MacBook power rails for repair.
                      by SarcasticOP
                      I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
                      • PPBUS_G3H (12.6V-12.8V)
                        • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
                      • PP3V42_G3H (3.42V)
                        • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
                      • PPVRTC_G3H (3.3V)
                        • This
                      12-12-2024, 05:50 PM
