Samsung R530 Partial Boot?
  • coltron
    • Jan 2021
    • 98
    • England
    Hi
    Hoping someone can help with a problematic Samsung r530.
    Core i3 1st gen, and PCH. no dedicated graphics chips.
    Sypmtoms:-
    The laptop powers, the display wakes, but shows no logo.
    After a few seconds , the screen displays solid white, then red, then green etc.The keyboard still has some functionality e.g. mouse lock, screen brightness, but thats about all.
    Cmos reset = no change
    Pressing F2/f10/f12/esc during boot has no apparent effect
    Tried:-
    Stripped the board to bench mode,( board, cpu and ram)
    CPU and PCH have had new thermal grease, and another cpu has been installed with same result.
    conected external monitor with HDMI port and VGA port to an external monitor, toggling display function key however both routes show
    Win 10 USB does appear to load (flashes during startup), not sure how far though.
    I've taken voltage readings from the power rails and all appear to be ok?
    Tried several known working RAM modules to no evail.
    No obvious shorts on media ports and board looks fine under the magnifying glass.
    Possible BIOS issue,? (I,m open to other theories) but how to flash when only bios download is a windows based app?
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Samsung R530 Partial Boot?
    Seems like motherboard is not posting. Connect a usb keybaord and check numlock glows or not. You need a spi bios programmer and desolder your bios chip. You can get a bios dump in this forum for your mb.
    • coltron
      • Jan 2021
      • 98
      • England
      Thank you,
      On your advice I have tried usb keyboard and there is no life from caplocks led.
      Same with laptop keyboard, no cap lock light during power on.
      Spi bios programmer?
      • coltron
        • Jan 2021
        • 98
        • England
        is a CH341A bios programmer ok?
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Yes, will do the job.
          • coltron
            • Jan 2021
            • 98
            • England
            Thanks I will get one
            • coltron
              • Jan 2021
              • 98
              • England
              Bios programmer arived today.
              I,m assuming that the chip has to be de-soldered, but havn,t a clue on how to use the programmer or how to get a bios for my motherboard?
              • coltron
                • Jan 2021
                • 98
                • England
                Bremen c rev 1.1(100210) 4
                chip .04 jv
                any help appreciated
                • coltron
                  • Jan 2021
                  • 98
                  • England
                  schemait would be great too
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    There is BA-- number silkscreened on the mb somewhere(very likely around dimm slot). Ask for bios in "bios section" with mb marking mentioned above by you+ BA number.
                    • coltron
                      • Jan 2021
                      • 98
                      • England
                      Thanks mcplgl123.
                      I have the programmer, however the software to use it isn't with the usb stick.
                      I found drivers online, but no software?
                      • Stevedb
                        Stevedb
                        • Feb 2018
                        • 624
                        • Belgium
                        Hi
                        Here do you have 2 good programma to use with Ch341A programmer.
                        Colibri, Neoprogrammer en ASprogrammer
                        Best regards
                        Steve
                        • coltron
                          • Jan 2021
                          • 98
                          • England
                          Cheers Stevedb,
                          much appreciated
                          • coltron
                            • Jan 2021
                            • 98
                            • England
                            ok have the software, have the programmer, lets get the bios for:-
                            BA92-063798
                            • Scotchmist
                              • Apr 2019
                              • 60
                              https://www.badcaps.net/forum/showthread.php?t=39885
                              • coltron
                                • Jan 2021
                                • 98
                                • England
                                Thanks Scotchmist
                                • Stevedb
                                  Stevedb
                                  • Feb 2018
                                  • 624
                                  • Belgium
                                  Hi Coltron
                                  You are welcome.
                                  Did you succeed to fix the laptop.
                                  Regards
                                  Steve
                                  • coltron
                                    • Jan 2021
                                    • 98
                                    • England
                                    Hi Stevedb
                                    Still working on it
                                    The first flash supplied was R540 BIOS. Resulted in a no start condition.
                                    I,m trying an "outage bin", from the same supplier. Ive still got scotchmist to try too
                                    I will keep up the post
                                    • coltron
                                      • Jan 2021
                                      • 98
                                      • England
                                      Outage bin flashed onto chip and the mb won't start.?
                                      • Stevedb
                                        Stevedb
                                        • Feb 2018
                                        • 624
                                        • Belgium
                                        Maybe you must ask somebody to extract the bios from the website from samsung.
                                        I do not know how to do it.
                                        Good luck
                                        Best regards
                                        Steve
                                        • torchzack
                                          Samsung 55" TV - Boot loop but sometimes works fine - UE55MU6470U
                                          by torchzack
                                          Hi Team - just joined to see if anyone can offer some expertise in diagnosing an issue with a TV.
                                          I've done a few hours googling and youtubing but just seeing if anyone has any insight here. I got a 55" Samsung UE55MU6470U which seems to boot loop and then after 10 mins will boot, work for a few minutes, then turn off and repeat.
                                          Whilst it's on into the normal Samsung menu/boot screen it looks perfect - so I can't see there being any screen issues. I've seen lots of videos with taping across clock lines to diagnose which particular one may be an issue but i don't...
                                          08-28-2023, 07:42 AM
                                          09-07-2024, 05:50 AM
                                        • eigma
                                          Samsung UN40H5003 boot loop every ~8 seconds
                                          by eigma
                                          Hi, I rescued a Samsung UN40H5003AF (H = 2014 FHD) from the curb. Symptoms are: standby (red) light comes on, stays on for 8 seconds, flickers off, then comes back on, and the cycle continues.
                                          Service manual: https://www.electronica-pt.com/esque...is-u8la-71272/
                                          SMPS board: checked voltages, all seem normal (A13V = 12.8V, UD = 3.3V, PWM_BLU = 0.77V, PS_OnOff = 5.5V). Remove 10p cable to main board -> backlight comes on. I think this means SMPS board and backlight are good.
                                          Main board: BN94-07592P / BN97-08922R...
                                          11-20-2024, 10:31 PM
                                        • NolesFan
                                          Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                                          by NolesFan
                                          Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                                          10-24-2024, 06:36 PM
                                          Samsung R530 R730 NP-R530 NP-R730 Laptop Schematic
                                          Samsung NP-R530 NP-R730 Laptop Schematic
                                          R530 R730...
                                          10-18-2024, 02:42 AM
