hp dv6000 quanta at8 gpu problem
  • disorder
    • Sep 2015
    • 154
    • france
    hello,
    i have a dv6000 f700 quanta at8 laptop with gpu error.
    i want to switch off it but don't find any advice about it (the motherboard could be work without gpu i know)
    schematics not clear about that
    can someone knows if i can do this ? and how ?
    thank you guys !
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: hp dv6000 quanta at8 gpu problem
    Dont waste on this crap motherboard. New chip are not available and its not possible to convert from dis to uma.
    • Sametbey
      • Jan 2021
      • 229
      • Turkey
      Many modifications and northern chip changes are needed. troublesome,
      I'm not happy to be so strong. because it's not humanly
      • piernov
        • Jan 2016
        • 4435
        • France
        Quanta AT8 is the AMD model with both failing GPU and MCP. They're a lost cause since there is no good replacement MCP available.
        Should be able to replace the board with the Intel version without dGPU (and get the appropriate heatsink as well). Quanta AT6 or better Quanta AT3, but I'm not 100% sure they fit.
        • theone111
          by theone111
          3. Problem: TV shuts down
          07-22-2024, 10:36 AM
        • Zeonalbasta
          Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
          by Zeonalbasta
          i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
          The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
          09-13-2024, 01:17 PM
        • Gibon378
          Problem with stopping audio and video for no reason
          by Gibon378
          PC Specs:
          • CPU: Ryzen 5 1600
          • GPU: GTX 1080 Palit JetStream
          • MOBO: ASRock ab350 PRO4
          • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
          • PSU: XFX 650W (don't remember what model)
          • OS SSD: ADATA SP920
          • OS: Windows 10 21H2
          Problem description:
          Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
          11-19-2022, 09:41 AM
        • perzyk23
          Lenovo T580 - LCD Panel problem - error 0288
          by perzyk23
          Good morning,
          I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
          10-25-2024, 12:42 AM
        • SDNarcia
          Dell 15R-5521 keyboard problem (KBC?)
          by SDNarcia
          Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
          As additional information,...
          07-20-2024, 10:47 PM
