Macbook Pro A1706 820-00239 No power, No liquid
  • Eddieno93
    • Apr 2020
    • CZ
    Hi guys, i have a problem with board 820-00239-A (no liquid damage). In short was U8000. After change still no power on but charging. I try change U7800 but still doesn't work. Here is all result:
    3V3_G3H - 3,3V
    PPBUS_G3H - 13,05V
    PP3V0_G3H - 3,078V
    PP3V3_S0 - 0V
    PP3V3_G3H - 3,404V
    PP3V3_SUS - 3,352V
    PP3V3_S5 - 3,354V
    SMC_DELAYED_PWRGD - 0V
    CPU_VCCST_PWRGD - 0V
    SMC_ONOFF_L - 3,4V
    RTC_RESET_L - 3V
    ALL_SYS_PWRGD - 0V
    S5_PWRGD - 3,265V
    PLT_RST_L - 0V
    PCH_INTRUDER_L - 3,078V
    PCH_SRTCRST_L - 3,057V
    PPVCCPRIMCORE_SUS_PCH - 1V
    PM_PCH_PWROK - 0V
    PM_PCH_SYS_PWROK - 0V
    PM_SLP_S5_L - 0V 100kO to GND (R1454)
    PM_PWRBTN_L 3,3V
    PM_RSMRST_L - 3,351V
    PM_BATLOW_L - 3,335V
    PM_DSW_PWRGD - 3,4V
    PM_SLP_SUS_L - 3,354V
    PM_SLP_S0_L - 3,352V
    PM_SLP_S3_L - 0V
    PM_SLP_S4_L - 0V
    PM_SLP_S5_L - 0V
    PM_SLP_S0S3_L - 0V
    PPBUS_HS_CPU - 13,04V
    PPBUS_HS_OTH5V - 13,04V
    PPBUS_HS_OTH3V3 - 13,04V
    PPBUS_S4_HS_TPAD - 13,05V
    PPBUS_PMIC - 13,06V
    PP5V_S5 - 5,01V
    P5VS4_PGOOD - 0V R7801 100kOhm and diode 0,425V
    S5_PWRGD - 0V, R7802 85,5kOhm and diode 0,456V
    After change U7650 S5_PWRGD is still 0V but now R7802 is 100kOhm.
    Any suggestions?
  • rilley
    MacBook Pro 13inch 2017mid (A1706 820-00923-A) - liquid damage - USBC and Display short circuit
    by rilley
    I am new into this, sorry to post it here. I want to make this as a pet hobby project, as this mac is not urgent.
    I have (Macbook Pro 13inch 2017mid) A1706 820-00923-A
    My mac had liquid damage a long time ago, the connector from J8500 is damaged on pin 46 (PP5V_S0_ALSCAM_F), I guess the LCD/display panel is in short circuit, as I saw the connector from the LCD burned as well.
    And the resistor L4004 is literally burned.
    From what I see from the schematics, it does not affect any other rails, only the connection to the display...
    07-10-2024, 01:57 AM
  • gabrielA7
    Macbook pro A1706 / Backlight flex cable compatibility
    by gabrielA7
    Hey guys!!
    I’ve got a question here!
    I have a MacBook Pro A1706 that needs the backlight cable replacement — the well-known issue — but the problem is that the code on my original cable is 821-00571-A, and the one I have on hand to install is 821-01229-A.
    Well, I asked ChatGPT about it, and the guy told me they’re not compatible and it could even burn the backlight circuit!!
    Here’s what the bot told me:
    I said to him: “I’m going to install the 821-01229-A.”
    ChatGPT replied:
    Understood — but before you solder or install the 821-01229-A,
    11-11-2025, 03:26 PM
  • questore
    nvme and wifi error after liquid metal spill
    by questore
    Someone brought me a liquid metal damaged motherboard.
    First I have removed alll liquid metal from the board.
    0,75V_ALW was burned, and had to be removed and I have separated the layers until no short was on the VIN (B+) line and the output is no longer shorted.
    Applying 0,77V on the output with my lab PSU make the laptop caming on and i running windows from USB drive SSD
    There are 2 things that not working.
    1. The WIFI card keeps turning off and on with an error code 43 and 10 abouth every 10 seconds
    2. nvme devices are not detected on either of the 2 slots....
    11-11-2025, 01:16 AM
  • silver60618
    How to clean Liquid Metal from under CPU?
    by silver60618
    Hi all, Im working on a board, that my customer brought to another shop, and smeared liquid metal all over the board.
    The laptop powers on, then shuts off. I noticed traces of Liquid Metal near the edge of the CPU, but I fear some maybe underneath.
    Has anyone ever tried Ultrasonic cleaning, or compressed air to remove or agitate the liquid metal?
    07-11-2025, 01:47 PM
  • Hondaman
    Liquid cooling?
    by Hondaman
    I hope my computer does not randomly reboot while typing this. My main system is the AsRock 970A-G/3.1 motherboard with the AMD 8150 chip. I am experiencing FREQUENT and RANDOM reboots once the system is used for a couple of hours (sometimes it reboots before I even get to the Win7/Linux Mint dual-boot screen). The problem MIGHT be the DRAM controller chip (I recently upgraded to the maximum 64 GB RAM). It also might be the VRM chips. I am using a typical aftermarket CPU cooler, which does NOT blow air DOWN onto the VRM heat sink.
    (After previous generation hardware [Gigabyte] didn't...
    05-08-2025, 09:37 PM
