I got a Lenovo x220 board H0225-3 48.4KH17.031 LDB-1 with fan error at post screen and laptop turning off immediately. Fan doesn't work in laptop but with external ps fan works fine. Any hints on what to check?
Lenovo x220 fan error.
Re: Lenovo x220 fan error.
look fuse near connector maybe
on t470 it's here look pics
https://www.facebook.com/maxrepar/ph...17381075114250
by coasterghostFor Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
System Hardware:
Processor: AMD Ryzen 7 PRO 5850U
Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...09-08-2025, 10:46 PM -
by Maxpower3Info for error 2202 LenovoThinkPad models and type
Extract from ThinkPad Maintenance Utilities Configuration File
plnsrv.ini Version 1.01
Some information that may be useful
There must also be missing models, add them to the list if you know of any.
...Code:brand name 20B1=ThinkPad Edge E445 20B2=ThinkPad Edge E545 20BC=ThinkPad Edge E145 20BM=ThinkPad X140e 20BL=ThinkPad X140e 20A3=ThinkPad X230s 20AH=ThinkPad X230s 20AK=ThinkPad X240s 20AJ=ThinkPad X240s
Channel: BIOS Requests ONLY!
by NecroFlexHello, i have 2 of the same machines, the 1st one is dead, it is plagued by this issue (same board model):
https://www.badcaps.net/forum/troubl...=4#post1606399
So it's not worth saving (flashes lenovo logo for a sec, then reboots to a black screen), the 2nd one only has the fan error that stops it from booting unless you press F1. I'd need the error removed so that the system...-
10-17-2024, 06:44 AM -
by Sus256Hi all!
HISENSE 65E7KQ PRO
RSAG7.820.13512 - chassis
MT9618BAATAB - cpu
RSAG7.820.12059 - power
HD650Y3U77 - panel
KLM8G1GETF - emmc
Replaced emmc.
Terminal log
UART
AC_ON
E-B
FDE enabled
layout pattern onebin by SAR7,0... -
by Good2KnowHi.
I bought a defect laptop for training porpus (maiboard troubleshooting /repair etc).
As advertised by the seller it turns on, fan spin but no display.
First thing i did was disconnect anything (ribbon cables) that could eventually cause the display not to work.
Still no display, not even via hdmi.
But after removing display cable off the mainboard it worked "perfectly" fine via hdmi.
So i installed a spare ssd and installed win10 without any issues.
With all the drivers installed via win update and lenovo vantage i went back to bios... - Loading...
