HP mini 1104 with board no DA0NM3MB6E1 REV:E Not charging, not power
  • dfortress
    • Oct 2017
    • nigeria
    Please Help.
    Hp Mini 1104 with board no DA0NM3MB6E1 REV:E Not charging not power.
    When the power adapter is connected to the unit, the led on the adapter blinks continuously.
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: HP mini 1104 with board no DA0NM3MB6E1 REV:E Not charging, not power
    dissemble the laptop and find out the 19V cross up to CLR resister and check 3/5V alws is ok or not ?
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      LED on the adapter blinks-Thats a sure sign of shorting in +19V rail.
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • Cryogen
        Mini pc board no charging, no lights.
        by Cryogen
        Hi
        I have this mini pc board who refuses to charge and it is completely dead. No charging light would come on when plugged in.
        The battery shows 11.95v from the 11.85v nominal
        There are 4 mosfet (2 front and 2 back of the board) near the battery connector. only one gives 11.95v readings the other 3 show 0v.
        Is the one reading 11.95v shorted? Or the one showing 0v next to the 11.95v readings that it is the culprit?
        edit: the one with voltage is showing a short on gate, drain and source as well.
        07-15-2023, 02:29 AM
      • howardc64
        by howardc64
        07-24-2025, 05:17 PM
      • master3112
        by master3112
        07-29-2025, 01:55 PM
