Alienware M17X R2 AB 4400 - no backlight
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3627
    • slovakia
    Hello.
    Have this Alienware M17X R2 AB 4400 on i cannot enable BKL. Ha two displays one with CCFL and othe with LED backlight
    Attach my readings. i try to even inject missing PWM and BKL power but not work
  • Rhadu23
    • Mar 2021
    • 74
    • United Kingdom
    Re: Alienware M17X R2 AB 4400 - no backlight
    Are you sure them displays are working?
    Also, make sure the display cable is well sited in the socket.
    I have the same Alienware and had same issue with it and turned out to be the cable not properly sited.
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3627
      • slovakia
      eah i know that. dont know if both screen are good. but have picture and no backlight on it. one of it is brand new
        • 21917
        Test voltage on R21 , check for any activity on Q17,Q19 pins 1 and 3 on both,and attach the keyboard and try the brightness setting FN whatever
        • Rhadu23
          • Mar 2021
          • 74
          • United Kingdom
          also try to reset the display by press the Windows logo key, the Ctrl key, the Shift key and B at the same time
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3627
            • slovakia
            this could not be on full brightness on start?
            R21 no voltage, but i try to inject and no joy
            Q17 have 0.17V on pins 3 and 1 , 3.3V on pin 2
            Q19 have 0.0V on pins 3 and 1 , 3.3V on pin 2
            i foung SMBCLK1 and SMBDAT1 shorted. 1.2ohm to GND when off and 13.5ohm to GND when started
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3627
              • slovakia
              What is normal resistance so i can track the problem?
                • 21917
                Don`t know . If theres no voltage on SMBCLK1 it could be a problem with the EC .
                • ktmmotocross
                  Boardkiller
                  • Feb 2014
                  • 3627
                  • slovakia
                  i think u have right. no SMB mosfets is shorted and i found little burn mark on EC
                  • ktmmotocross
                    Boardkiller
                    • Feb 2014
                    • 3627
                    • slovakia
                    i found chip with same marking so i try to replace it
                    • ktmmotocross
                      Boardkiller
                      • Feb 2014
                      • 3627
                      • slovakia
                      looks like it worked. Inverter WORK and even Fans work normal
                      but there is another weird problem, that start after EC change
                      MAIN_PWR_SW# go only to 2.2V when i press pwrbtn so it not start
                      Before R6 3.3V go to 0.0V when press button, but after R6 it it go only to 2.2v
                      when i short after R6 to GND laptop start.
                      R6 and R3 have measured the right restance
                        • 21917
                        Your original chip is marked JXD ,your replacement is DXS .See if you can get one exactly the same
                        • ktmmotocross
                          Boardkiller
                          • Feb 2014
                          • 3627
                          • slovakia
                          dont have that. i must order one
                          Replaced R6 - 10K with 4.7K and now MAIN_PWR_SW# does down to 0.22V and laptop start
                          for now i test it if it have any other issues because of different ic
                          • ktmmotocross
                            Boardkiller
                            • Feb 2014
                            • 3627
                            • slovakia
                            so far everything works
