repairlap.com for real?
  • drscoot
    • Dec 2020
    • 44
    • Belgium
    Anyone already used this site? There are lots of schematics and bios available, but it looks to good to be true.
    • 21914
    Re: repairlap.com for real?
    Its a paid site, meaning they charge for bios/schematics etc ,unlike badcaps thats totally free .Personally i never used them and no intention to.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      @drscoot, if you indeed want to pay for subscription or buy specific files, teknisi indonesia is better option then repairlap.com. However, as @piernov said, why pay when there is badcaps.net available. However, certain schematics/boardview you can get only on paid sites-so choose your discretion.
      • menshawy
        • Aug 2013
        • 400
        • egypt
        badcaps.net is best
        • speaktorob
          • Mar 2024
          • 13
          I just found out that the boardview I got from repairlap that I've been working with has gotten the 1.8V and PEX coils mixed up. It also seems to have references to components that aren't there. I'm going with "avoid"
          (forgive the necro, but since this post comes up in the top 10 right now on Google for "repairlap" I wanted to add my two cents)
          • cnti
            Samsung 245B PLUS - BN44-00195A - bang and smoke - solved - tips
            by cnti
            Hi.
            BacCaps forum is awesome - thank YOU ALL for sharing knowledge!
            This is about DONG YANG PSU BN44-00195A failiure in Samsung 245BPLUS. It started with bang and smoke from the back of LCD. Downloaded diagram BM44-00192A - a bit different but I will use all parts names from this diagram [and real PSU].
            BIG CAP CP801 had 315V, on standby pin 5,2V. After shorting S_B ON (through 3,3k ohm resistor) 24V and 5,3V were missing, on CP801 was 312V.
            RM801 [real PSU: RM801 - 0,22 ohm 1W] - FAIL
            burned, measured 10M ohm.
            QM801 [real PSU:...
            10-19-2023, 05:33 PM
          • mo000
            IS THAT TRUE? dynabook no power .
            by mo000
            hi
            i have dynabokk c50-g-102 i5 10th gen
            IP3_CN16S_MB_V20_202001229B
            the laptop die no power no charging led no nothing
            i can't find schematic or boardview
            no short on motherboard
            19v stop on source of pq2 drain=0v
            on the gate of pq1 and pq2 =18.5v qnd source 19v but pq1 and pq2 qre pchannel which is means the source voltage should be lower
            what i know is gate of pq1 and pq2 controlled by charger ic here is bq24780s but vcc of bq=0v which means ther is somthing else controlling mosfet gate
            i think kbc IT8987E is controll the gates of both...
            08-25-2025, 07:57 AM
          • DynaxSC
            by DynaxSC
            11-17-2023, 10:56 AM
          • shelby5041
            old trs80 computer lots of smoke
            by shelby5041
            hi
            my neighbor gave me an old radio shack trs80 model3 computer...it was stored in his attic for 35yrs...i powered it on and after 5min lots of smoke was coming out of computer...i took it apart and didnt notice any fire evidence so i assume a cap split open...i looked around only saw 1 suspect part...see photo...could this be the smoke?
            07-14-2024, 05:11 PM
          • DynaxSC
            by DynaxSC
            06-14-2024, 03:49 PM
