HP 15 LA- A994P no Backlight and picture !
  • lapfix
    • Mar 2020
    • 2764
    • my workshop
    HP 15 LA- A994P Turn on without Backlight and picture , but everything is displayed normally on the external monitor.
    Changing Screen and flexible same issue.
    JLVDS1
    Pin 1/2 = +LCDVDD = 0v
    Pin 23 = DISPOFF# = 0v
    Pin 24 = INVTPWM = 0v
    Pin 27/28 = INVPWR_B+ = 19v
    Pin 32/33 = +3VS=3 .42v
    UG1 don't exist , so + lcdvdd is taken from RTD2132S itself pin 15 = +DP_ENVDD = 3.45v.
    No component from Pin 15 until pin 1/2 JLVDS !
    What to check else friends !..thank you .
  • peste
    • 13619
    • ROMANIA
    Re: HP 15 LA- A994P no Backlight and picture !
    JLVDS1
    check the route between RTD2132S and the LVDS cable socket so that it is not interrupted.
    • lapfix
      • Mar 2020
      • 2764
      • my workshop
      Thank you my friend.
      I can't find any continuity between pin 15 of UT1 and any other components
      Maybe a boarderview can help to trace it !..don't have.
      At page 16 there's a Resistance = RT9 with @..but even have @ and is present at the motherboard..
      • Sametbey
        • Jan 2021
        • 229
        • Turkey
        When you look at the block diagram, RTD2132S provides the connection between the processor and the LCD panel. 3 4 pins of JVDS socket LCD panel data connection. To detect when the LCD panel is installed. If you have an oscilloscope, you can check the input signals. You can try bios pgm first.
        I'm not happy to be so strong. because it's not humanly
        • lapfix
          • Mar 2020
          • 2764
          • my workshop
          Thank you Sametbey.
          Don't have oscilloscope for the moment...about bios i think when there's display at external so no need for flashing bios !! am i right !
          • peste
            • 13619
            • ROMANIA
            Thank you Sametbey.
            you don't need bios ...
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              @lapfix, i Know UG1 dont exist on the board but can u measure voltage on PIN5/3/1 of UG1 pads.
              • lapfix
                • Mar 2020
                • 2764
                • my workshop
                THank you mcplslg.
                Pin 1 = 25mv
                Pin 3 = 26mv
                Pin 5 = 3.3v
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  So Enable is missing. You can try shorting pin5 & pin1 and see if there is display. However, do check resistance on pin1 before shorting.
                  • lapfix
                    • Mar 2020
                    • 2764
                    • my workshop
                    mcplslg thank you again.
                    So strange this motherboard ..so before shorting pin 1/5 i check pin 1 resistance , finding 32 Kohm so it's OK , but i try in diode mode that i always work with it ( diode mode ) ..finding 0.524v at pin 1 so all is ok...now try with screen and ready to short the 2 pins..and a surprise there's a display before shorting!!..all is OK !..measure UG1 pin 3 and there's 3v enable ...maybe the pulse of diode mode voltage do something !
                    • lapfix
                      • Mar 2020
                      • 2764
                      • my workshop
                      Update :
                      After assembling the lap..same issue no display...try another flexible /screen : sometimes it work and other no.
                      when working it's not stable , sometimes i got backlight and picture...sometimes no
                      i order a third flexible to confirm !
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        I dont think 2 flex cable will be bad. Issue seems to be related to mb. Have u tried jumpering pin5 & pin1 when there is no display on internal screen??
                        • lapfix
                          • Mar 2020
                          • 2764
                          • my workshop
                          i try , there's a backlight but no picture
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            Hmm... I doubt it may be SOC . Do you have bga machine??
                            • lapfix
                              • Mar 2020
                              • 2764
                              • my workshop
                              No my friend , maybe try to make a brief heating , if not i have nothing else to try...thank you for all your support
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                I'm afraid heating with blower may damage the soc. Bga machine is a must to heat soc .But since you dont have a bga machine, dont heat the soc on top with a blower. Instead heat it a bit on back side and see if there is display.
                                • lapfix
                                  • Mar 2020
                                  • 2764
                                  • my workshop
                                  Hello my friend...that's how heat it , from back side a little but no result.
                                  Strange thing : i try another dump from here and backlight is OK , but no picture !
                                  • mcplslg123
                                    • Jun 2015
                                    • 7262
                                    • india
                                    Somewhat similar fate to your earlier post of LA-E791/802P. You really cant do much with newer mb's as mb components are not labelled and very often SOC's fail. Schematic/boardview are available only on paid sites making the whole repair unviable. We cant help it but has to cope with it.
                                    • lapfix
                                      • Mar 2020
                                      • 2764
                                      • my workshop
                                      Again , thank you for all your advices , yes you are right .
                                      • triplefour
                                        by triplefour
                                        09-13-2023, 10:43 PM
                                      • TR103
                                        by TR103
                                        - it keeps rebooting
                                        01-22-2025, 04:12 PM
                                      • Mgiffune
                                        by Mgiffune
                                        06-09-2024, 10:28 AM
                                      • Ierwin
                                        by Ierwin
                                        05-13-2025, 03:31 PM
                                      • groomit
                                        Philips 50PUS7363/12 Backlight but no picture
                                        by groomit
                                        I'm having trouble with above mentioned TV. Bought it defect.
                                        Picture was heavily compressed around the horizontal axis. Fiddeled and tried different things (mask clock lines, swap T-Con). But no difference.
                                        Then I identified a heating capacitor on the left hand Signal-PCB (?) below the display. Replaced it by hand soldering. Checked for shorts afterwards. But now the screen stays black.
                                        I can see backlight, but screen stays black.
                                        What I've tried:
                                        - Disconnect right side cable from T-Con -> same (backlight but no pic)
                                        - Disconnect left side...
                                        11-22-2024, 02:43 PM
