Hope someone can help with diagnosing/fixing a dell 1558 that I've been working on, with the aid of Quanta FM9C schematic and boardview, (downloaded from this site...Thanks
Original symptom was shorted Mainboard, cutting out the psu.
PQ41 (high side Mosfet on 1.5v Rail) got warm when 19v rail was injected with 5V-2a.
The Mosfet was changed out from a donor board, and the short disappeared, but the laptop wouldn't start and would only charge the battery.
On inspection the voltage regulator chip Tps51116 showed signs of a previous repair .... a blown trace next to pin 23 (VBST).
I've re-bridged the trace today and the laptop now starts, as soon as 19v is plugged in. Fan spins at full chat immediately, but no display. PQ41 gets hot, very quickly. I get a low ohm reading from 1.5v coil to ground 3ohm..?
I took off a couple of caps, but then i notice quite a few on Dram that I,m reluctant to lift, as the problem may lay elswhere. (When coil is lifted, the low ohm short apears on 1.5v sus... Any advice? (other than the bin)
