signal measure points, yellow numbers?
  • prow
    • Jul 2020
    • 14
    • croatia
    Hi to all, maybe a stupid question but i am new here and tried to learn regarding motherboard repars..
    So, the question is regarding repair guides for laptops. For instance i attached pdf regarding asus g752vl repair. I did understand most of the guide but what puzzles me is section Signal Measure Points (last two pages). I understand that those are signals that needs to be checked..and with red number it is described what is a sequence in time.... what singal comes first and what last. But what are those yellow numbers? for instance AC_BAT_SYS number is 436? is that resistence in ohm? but i dont think so..
    thx for help!
  • mon2
    • 14659
    Re: signal measure points, yellow numbers?
    I think those are DIODE readings. Place your meter into DIODE mode, connect your RED probe (yes RED probe) to GROUND. Connect the BLACK probe to the point you wish to measure.
    Compare the reading to the PCB readings. If they are close, the test point is OK.
    • CoinCoin88
      Garage door RX unit (Cardin S38C) does not short relay to send opening signal
      by CoinCoin88
      I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
      Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
      09-15-2025, 03:36 AM
    • howardc64
      Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
      by howardc64
      Failure Symptom
      No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
      Where is the short?
      Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
      Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
      05-27-2025, 02:56 PM
    • JayPoorJay
      Converting +/- 5v to a Usable Hz Signal
      by JayPoorJay
      Good morning.
      I have posted here before and have gotten AMAZING advise (thank you!). I'm back for more. This BCaps Sub Forum is so well attended I thought I would post here.
      This question is for an automotive application but has to do with what are essentially electrical questions and problem solving... If this is inappropriate I get it. Feel free to delete it or move the question.
      The V 12 Jaguar XJS is notorious for overheating in stop and go traffic in hot weather... Y'all will be potentially helpinh a LOT of people. The solutions and directions...
      08-07-2022, 08:35 AM
    • supravit2000
      PS4 fat has inconsistent signal after HDMI replacement
      by supravit2000
      Hi, guys!
      I am not a professional, all I can do is solder stuff on the boards, so I would really appreciate it if someone with knowledge shares his experience/thoughts on a problem I have with a PS4 console.
      My friend gave me an original fat PS4, board model SAB-001, with WLOD, that has been previously opened. I changed the HDMI port, couple of pads on the board were ripped, which I connected to the corresponding caps/resistors? Just did so as in a shown diagram (one of the ground pads I ripped off and left it not connected). However, there was still no signal, so...
      12-19-2022, 08:08 PM
    • Ellos
      Samsung s21 sim recognized but no signal
      by Ellos
      I'm just starting out with smartphone repairs and picked up a Samsung S21 to work on. Everything functions perfectly except there's absolutely no cellular signal. The SIM card is recognized, WiFi works fine, but zero network signal.
      I've tested my SIM in another phone and it works perfectly with good signal, so it's definitely the phone.
      From what I've read online, this issue is usually caused by the network chip needing to be desoldered and reballed since one of the solder balls might be cracked.
      I think I've located the SOC that...
      06-27-2025, 01:31 AM
