Lenovo Ideapad Z500 - power LED for 6 seconds
  • TheGiolly
    • Aug 2014
    • 8
    • Italy
    Hi, I have a Lenovo Ideapad Z500 with motherboard VIWZ1_Z2 LA-9061P.
    After pressing the power button, the power LED comes on for about 6 seconds and then shuts off.
    +5VALW, +3VALW, +5V_PCH, +3V_PCH and are all ok.
    I have missing +5VS, +3VS, +1.5VS and all the other main power rails due to the signal SUSP (generated by the EC KB9012QF-A3) stuck at GND.
    The signals SLP_S3#, SLP_S4# and SLP_S5# (from PCH to EC) are all stuck at GND too while SLP_SUS# (from PCH to EC) is at +3V.
    The signal RSMRST# (from EC to PCH) is at +2V.
    Could comeone please help me out to find the problem?
    Thanks in advance!
  • Dr.d
    Help please..Lenovo ideapad 5 14itl05 power and charging problem
    by Dr.d
    I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
    Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
    04-05-2024, 11:48 AM
  • Mita99
    Lenovo Thinkpad P72 EP720 NM-B723 MB - Power disabled within 2 seconds after plugging the charger
    by Mita99
    Try to repair a Thinkpad P72 EP720 NM-B723 MB with I7-8850H processor and N18E-Q1-KB-A1 (P3200) GPU with 6GB memory. Unfortunately there is noinfo what happened to the laptop. I got it disassembled with parts missing, like keyboard, battery.
    Unfortunately I have no schematic available for me (requested in the sub porum) but got the boardview file.
    Symptom: after connecting to the charger the power led light up for one-two second and switch off. After a couple secons the power led light up for half a second and switch off. No battery, no IO board, no...
    04-27-2025, 07:20 PM
  • gleniu
    Lenovo IdeaPad Gaming 3 15ACH6 - no power
    by gleniu
    Hi, I have a problem with a Lenovo IdeaPad Gaming 3 15ACH6 laptop. My nephew asked me to replace the charging port because the laptop wasn't charging. This issue had happened in the past, so I knew that replacing the port was only a matter of time. Until now, my nephew managed to deal with the problem using a temporary solution: bending the positive metal tabs inside the port with a thin tool. However, this had stopped helping for a while. Today, I replaced the port – and to my surprise, after the replacement, nothing happens when I plug in the charger: the power LED doesn't light up, the laptop...
    Yesterday, 01:13 PM
  • rabsonnjala
    LENOVO IDEAPAD 100 works only on bench power supply
    by rabsonnjala
    Hie I have a Lenovo laptop
    Lenovo Ideapad 100-14IBY AIVP1-AIVP2 LA-C771P rev 1.0
    it's working only on the bench power supply when I put the battery it doesn't power on. when I also use the original charger it doesn't power. the batter Is fully charged, I used another laptop to charge the battery. but when I use a bench power supply it works perfectly
    below are my readings
    with the original charger only
    JBATT1
    PIN1 0.22V
    PIN2 0.22V
    PIN3 0.45V
    PIN4 0.45V
    PIN5 O.43V
    PIN6 0V
    PIN7 GND
    PIN8...
    11-20-2021, 08:32 AM
  • acata
    Lenovo Ideapad slim 3 not power on
    by acata
    Lenovo Ideapad slim 3 not power on after consumer problems is can not on after sleep mode.
    And the consumer asked for reinstalling OS.
    I reinstalled windows 10 and working fine. After i leave it for updating windows and goes to sleep mode. Now it cant draw any input from power supply.
    Motherboard number is GS450&GS550&GS750 MM-C821 REV: 1.0
    Check the main power rail for 20v input ok
    No amper input from Power supply 0.013a
    Mosfet PQ201 20v and 26v ok.
    3.3v exist
    1,8v exist
    5v exist
    12v from baterai exist....
    09-30-2024, 09:42 PM
