Asus X550VX not power on
  • lapfix
    • Mar 2020
    • 2764
    • my workshop
    Hello friends .
    Asus X550VX not power on.
    PWR_LED+ on / CHG_LED+ off / HDD_LED+ off / WLAN_LED+ Dim / NUM_LED+ on / CAP_LED+ on.
    PSU = 19v and only 0.06 amp taken , no variations after press button too.
    THis lap come to me with coil Ram short to ground ( Ram on board ) , so i disable ram and the short is gone.After that try to power on but no way .
    This is the measures that i take.
    Swich circuit OK.
    PU8900
    6=ACDET=2.6v
    5= ACOK =3.04v
    28= VCC =19v
    24= REGN =6v
    RTC circuit OK.
    RTCRST = 3.09v
    SRTCRST = 3.09v
    +3VA_RTC = 3.09v
    +3VSUS = 3.4v
    +5VSUS = 5v
    U3001 .
    14 = EC_RST = 3.3v
    66= PM_SLP_SUS = 3.4v
    97 = DPWROK_EC = 3.3v
    86 = VSUS_ON = 3.3v
    67 = 3VSUS_PWRGD =3.3v
    96 = PM_RSMRST_ = 3.3v
    72 = A_D_MAX_POWER = 2.8v
    56 PM_PWRBTN_ = 3v
    110 =EC_GPB3 ( pwr sw ) = 3v /0v/3v
    35 = PM_SUSB = 3.4v
    57 = PM_SUSC = 3.4v
    82 = SUSC_EC ( EC_GPE1 ) = 3.3v
    22 = BUF_PLT_RST = 0V
    I clean bios too but still the same...what to check else..thank you.
  • plaktuz
    • Sep 2021
    • phillipines
    Re: Asus X550VX not power on
    sir what happen to this?
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3627
      • slovakia
      many of disable ram guides not work. better repair that ram issue
      • GLISIT
        by GLISIT
        01-16-2025, 02:29 PM
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • PantherDave
        by PantherDave
        Hi all!
        05-29-2024, 02:01 PM
      • ShadowAi
        ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
        by ShadowAi
        Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
        Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
        After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
        03-15-2024, 10:46 AM
      • meraklinetx
        Asus Z97-a power cycle, no boot no cpu voltage
        by meraklinetx
        Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
        05-10-2023, 06:08 AM
