ASUS ZenBook UX433F No power
  • tlough75
    • Apr 2017
    • 33
    • US
    Hello, I am working on theis ASUS laptop and it is completely dead. I know laptops use 3.3V and, 5V, and 1.05V power rails, I can find the 5V power rail and the 19V DCIN rail as well as 1.05 but I cannot seem to get 3.3V. I tried to see if SPI was getting its power supply but It is measuring .5V on pin 8. I'm not exactly sure which chip creates 3.3V on the board. Does anyone have any examples of what chips to look for?
  • stingerchamp
    • Sep 2020
    • 425
    • Pakistan
    Re: ASUS ZenBook UX433F No power
    Share complete motherboard part number and search for schematic in search bar
    Yes 3.3v power up bios spi flash
    • tlough75
      • Apr 2017
      • 33
      • US
      Hi sorry, Motherboard Number is UX433FN Rev. 3.0.
      • GLISIT
        by GLISIT
        01-16-2025, 02:29 PM
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • PantherDave
        by PantherDave
        Hi all!
        05-29-2024, 02:01 PM
      • ShadowAi
        ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
        by ShadowAi
        Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
        Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
        After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
        03-15-2024, 10:46 AM
      • meraklinetx
        Asus Z97-a power cycle, no boot no cpu voltage
        by meraklinetx
        Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
        05-10-2023, 06:08 AM
