LENOVO NM-A841 Missing 5v/3v voltages
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    Re: LENOVO Missing 5v/3v voltages
    Originally posted by SMDFlea
    Have you found any resistors connected to the pin 11 trace or does it go into a via through the board ? A board view would help but I'm not sure if it's available. Take a picture of pu401 with the surrounding parts
    gos via the board sir
    • stingerchamp
      • Sep 2020
      • 425
      • Pakistan
      According to the nm-a841 schematic no ,but schematics aren't always right even though you expect them to be. It can't be 19v on pin 11. Let's gets other members views and fix this together
      If you look at datasheet abs max Volt of en is 25v
      I read it wrong?
      • kalilinux25
        • Mar 2018
        • 2089
        • ZAMBOANGA SIBUGAY
          • 21199
          I read it wrong?
          There is no datasheet for the SY8286BRAC .
            • 21199
            I read a post on a russian forum that pin 11 is indeed 19V .Just to be sure though inject voltage voltage on theat but but keep it low and slowly crank the voltage up.If you can get up to 19V then run a jumper between 2,3,4, or 5 to 11
            • kalilinux25
              • Mar 2018
              • 2089
              • ZAMBOANGA SIBUGAY
              #26
              jumper on pin 11 checking voltage on all pins
              PU401
              PIN1- 0V
              PIN2,3,4,5 - 19V
              PIN6 0V
              PIN7 0V
              PIN8 0V
              PIN9 0V
              PIN 10 0V
              PIN 11 19V
              PIN12- 0V
              PIN13-0V
              PIN14-0V
              PIN15-1.3V
              PIN16 - 0V
              PIN17- 0V
              PIN18-0V
              PIN19-0V
              PIN20-0V
              PU301
              PIN1 - 19V
              PIN2 - 19V
              PIN3 - 19V
              PIN4 - 19V
              PIN5 - 19V
              PIN6 - 5.8V
              PIN7- 0V
              PIN8 -0V
              PIN9-0V
              PIN10-0V
              PIN11-0V
              PIN12-19V
              PIN13-19V
              PIN14 -19V
              PIN15- 5.8V
              PIN 16- 0V
              PIN13
              • stingerchamp
                • Sep 2020
                • 425
                • Pakistan
                #27
                Pu301 is ok
                Change pu401
                Check capacitor pc422
                Apply 3.3v with dc at pc422 and check with multimeter voltage drops or stable if stable change pu401
                • kalilinux25
                  • Mar 2018
                  • 2089
                  • ZAMBOANGA SIBUGAY
                  #28
                  Pu301 is ok
                  Change pu401
                  I dont have a pu401 right now sir\ do i need to remove it beore adding voltage on pc422?
                  • stingerchamp
                    • Sep 2020
                    • 425
                    • Pakistan
                    #29
                    Yes remove it
                    • kalilinux25
                      • Mar 2018
                      • 2089
                      • ZAMBOANGA SIBUGAY
                      #30
                      Yes remove it
                      nothing is consuming at pc422 capacitor sir 3.3v no amp
                      • stingerchamp
                        • Sep 2020
                        • 425
                        • Pakistan
                        #31
                        Confirmed
                        Change pu401 and likely KBC as well
                        • kalilinux25
                          • Mar 2018
                          • 2089
                          • ZAMBOANGA SIBUGAY
                          #32
                          Confirmed
                          its ha s same problem with my acer hehehe
                          • kalilinux25
                            • Mar 2018
                            • 2089
                            • ZAMBOANGA SIBUGAY
                            #33
                            Confirmed
                            Good day sir I hope you can help me again I already cahnge the PU401 ic but I got the same reading on all pins
                            PU401
                            PIN1 - 0V
                            PIN2 - 19V
                            PIN3 - 19V
                            PIN4 - 19V
                            PIN5 - 19V
                            PIN6 - 0V
                            PIN7 - 0V
                            PIN8 -0V
                            PIN9 -0V
                            PIN10 -0V
                            PIN11 -19V
                            PIN12 -0V
                            PIN13- 0V
                            PIN14 -0V
                            PIN15 - 0V
                            PIN16 - 0V
                            PIN17 - 0V
                            PIN18 - 0V
                            PIN19 - 0V
                            PIN20 - 0V
                            ive tested the impedance of PL401 7KOHMS
                            PL402 27 Kohms is this normal sir?
                            • mat2k
                              Lenovo 300-15IBR - No SYSON, no SUSP#, bunch of missing voltages
                              by mat2k
                              Hello, I've been struggling with this one today. I'm troubleshooting a Lenovo 300-15IBR (board BMWC1/BMWC2 NM-A471) that turns on the power LED and does a bit of fan spin but nothing else. 3v3sb and 5vsb present, no 1.05v, no 1.35vddr, no vcore, no 1.8vsb.
                              BIOS has been reflashed with one I found here, supposedly tested OK by someone else. I don't have an EC programmer unfortunately.
                              I looked around and SYSON is 0v, SUSP# is 0v too. Forcing them to 3v3 enables the 1.35v rail, but the 1.05v and 1.8v rails are still missing (generated by PU704). EN_1P05A signal is 3.3v, and IN_1P05A...
                              12-01-2024, 11:00 PM
                            • TecnicaNTT
                              Lenovo Thinkbook 16P G2 ACH - BIOS Serial number missing
                              by TecnicaNTT
                              I got a Lenovo Thinkbook 16P G2 ACH on the bench with a botched BIOS (somehow my client blanked it). I restored the laptop and got it up and running with original BIOS from Lenovo Support website.
                              My problem is now that the machine details are missing in the BIOS (Serial Number, MTM, etc.)
                              I tried to write the details with the Lenovo Uone Tool but had now luck. It is giving me an error: "ERROR: Locate protocol with LenovoEeprom, Status=[e]. EEPROM fail when reading or writing data."
                              I am now asking here for help if anyone knows how to do this in...
                              09-20-2024, 08:10 AM
                            • maneatingmonkey
                              Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
                              by maneatingmonkey
                              I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
                              There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
                              03-27-2024, 07:17 AM
                            • karlp028
                              MSI Z390-A PRO missing VCORE voltages
                              by karlp028
                              I've got an MSI Z390-A Pro motherboard that starts up fine, but it's missing the VCORE (and VGT) voltages. All of the other voltages are present (e.g. VCCSA, VCCIO) and I know the CPU (i7-9700k) is good. Now, the original PWM controller (UP9521P) had an internal short and I replaced it with a new one. All of the enable signals look good. The problem seems to be the PWM signals going to the MOSFET drivers. I checked them with an oscilloscope and they are all flat 1.5V with no pulses. I don't know why this would be and I'm not sure where to look next.
                              06-23-2025, 01:25 AM
                            • m0jo1103
                              Need help.... Lenovo L340-15IRH mosfet missing!
                              by m0jo1103
                              Can someone please help me.. Mosfet is missing on this motherboard (Lenovo L340-15IRH) I cant find the part number.. Can someone please send me a picture or part number of the mosfet missing on the board.. Thankyou!
                              05-19-2025, 07:13 AM
