LENOVO NM-A841 Missing 5v/3v voltages
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    Hi board CG521 NM-A841 REV 1.0
    NO POWER
    PU301
    PIN1 - 19V
    PIN2 - 19V
    PIN3 - 19V
    PIN4 - 19V
    PIN5 - 19V
    PIN6 - 5.8V
    PIN7 - 0V
    PIN8 -0V
    PIN9 -0V
    PIN10 -0
    PIN11 -0V
    PIN12 -19V
    PIN13- 19V
    PIN14 -19V
    PIN15 - 5.8
    PIN16 - 0V
    PU401
    PIN1 - 0V
    PIN2 - 19V
    PIN3 - 19V
    PIN4 - 19V
    PIN5 - 19V
    PIN6 - 0V
    PIN7 - 0V
    PIN8 -0V
    PIN9 -0V
    PIN10 -0V
    PIN11 -19V
    PIN12 -0V
    PIN13- 0V
    PIN14 -0V
    PIN15 - 0V
    PIN16 - 0V
    PIN17 - 0V
    PIN18 - 0V
    PIN19 - 0V
    PIN20 - 0V
    Hi i hope someone can help me with this issue
    checling coil impendace PL501,PL401,PL402 is ok no shorted
  • Sephir0th
    • Oct 2020
    • 1283
    Re: LENOVO Missing 5v/3v voltages
    Is this with battery removed? Check if PQ309 and/or PQ303 is shorted (D/S/G). 19V on Battery Charging Rail is too much in my opinion.
    FairRepair on YouTube
    • kalilinux25
      • Mar 2018
      • 2089
      • ZAMBOANGA SIBUGAY
      yes without the battery sir
      pq309 and pq303 is not shorted sir
      • Techtiger
        • Oct 2014
        • 1602
        • france
        Check again pin11 PU401 cannot be +19V it should be approximately 3V-3.3V
        • kalilinux25
          • Mar 2018
          • 2089
          • ZAMBOANGA SIBUGAY
          Originally posted by techtiger
          Check again pin11 cannot be +19V it should be approximately 3V-3.3V
          sorry pin 11 has 0v sir
          • stingerchamp
            • Sep 2020
            • 425
            • Pakistan
            Pin 17 is vcc internal ldo output should be 3.3v here
            Pin 11 is enable2 can be 19v as connected to input supply, needed to turn on ic
            Pin12 is enable1 pin coming from KBC ec-on
            Pin---17=0 no ldo supply check again
            Pin---12=0 volt no en to generate pwm operation coil supply
            Pin11=supply to turn on ic
            • Techtiger
              • Oct 2014
              • 1602
              • france
              Test all requirements of SIO & pin 85 ? Yep correct EN2 is +19V EN1 can go up to +4.5V I have to get a new pair of glasses
              • kalilinux25
                • Mar 2018
                • 2089
                • ZAMBOANGA SIBUGAY
                pin 17 has 0v
                pin 12 0v
                pin 11 0v
                so the ic is dead? or other aprts?
                • stingerchamp
                  • Sep 2020
                  • 425
                  • Pakistan
                  Input voltage supply is missing, first check pin---11 voltage and how is it possible that you have 19v at pin 5 and not at pin11
                  Can not tell now
                  • kalilinux25
                    • Mar 2018
                    • 2089
                    • ZAMBOANGA SIBUGAY
                    Can not tell now
                    can i try to pump voltage in pin 11 sir?
                    • stingerchamp
                      • Sep 2020
                      • 425
                      • Pakistan
                      No
                      Check pin 5 voltage 19v stable or dropping
                      • kalilinux25
                        • Mar 2018
                        • 2089
                        • ZAMBOANGA SIBUGAY
                        No
                        very stable sir nothing is going drop
                          • 21517
                          Look at the trace on pu401 pin 11 ,are there any resistors connected to it. Don't inject any voltage on pin 11 ! .The LA-C371P schematic has pin 11 as ENLDO_3V5V ,it goes through a voltage divider.
                          https://drive.google.com/file/d/1NK6...OCOaFraFV/view
                          • stingerchamp
                            • Sep 2020
                            • 425
                            • Pakistan
                            Pin11 has no resistor as per schematic but check again
                            • kalilinux25
                              • Mar 2018
                              • 2089
                              • ZAMBOANGA SIBUGAY
                              nope sir I dint inject it .
                                • 21517
                                According to the nm-a841 schematic no ,but schematics aren't always right even though you expect them to be. It can't be 19v on pin 11. Let's gets other members views and fix this together
                                • stingerchamp
                                  • Sep 2020
                                  • 425
                                  • Pakistan
                                  I agree, physically check any resistor attached to this pin---11
                                  At least ldo should come out at pin---17 but since ic is not getting vcc no chance
                                  • kalilinux25
                                    • Mar 2018
                                    • 2089
                                    • ZAMBOANGA SIBUGAY
                                    whats the verdict sir?
                                    • stingerchamp
                                      • Sep 2020
                                      • 425
                                      • Pakistan
                                      Trace pin 11 to any resistor attached or not in beep mode
                                        • 21517
                                        Have you found any resistors connected to the pin 11 trace or does it go into a via through the board ? A board view would help but I'm not sure if it's available. Take a picture of pu401 with the surrounding parts
                                        • mat2k
                                          Lenovo 300-15IBR - No SYSON, no SUSP#, bunch of missing voltages
                                          by mat2k
                                          Hello, I've been struggling with this one today. I'm troubleshooting a Lenovo 300-15IBR (board BMWC1/BMWC2 NM-A471) that turns on the power LED and does a bit of fan spin but nothing else. 3v3sb and 5vsb present, no 1.05v, no 1.35vddr, no vcore, no 1.8vsb.
                                          BIOS has been reflashed with one I found here, supposedly tested OK by someone else. I don't have an EC programmer unfortunately.
                                          I looked around and SYSON is 0v, SUSP# is 0v too. Forcing them to 3v3 enables the 1.35v rail, but the 1.05v and 1.8v rails are still missing (generated by PU704). EN_1P05A signal is 3.3v, and IN_1P05A...
                                          12-01-2024, 11:00 PM
                                        • coasterghost
                                          Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                                          by coasterghost
                                          For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                                          Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                                          Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                                          System Hardware:
                                          Processor: AMD Ryzen 7 PRO 5850U
                                          Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                                          09-08-2025, 10:46 PM
                                        • TecnicaNTT
                                          Lenovo Thinkbook 16P G2 ACH - BIOS Serial number missing
                                          by TecnicaNTT
                                          I got a Lenovo Thinkbook 16P G2 ACH on the bench with a botched BIOS (somehow my client blanked it). I restored the laptop and got it up and running with original BIOS from Lenovo Support website.
                                          My problem is now that the machine details are missing in the BIOS (Serial Number, MTM, etc.)
                                          I tried to write the details with the Lenovo Uone Tool but had now luck. It is giving me an error: "ERROR: Locate protocol with LenovoEeprom, Status=[e]. EEPROM fail when reading or writing data."
                                          I am now asking here for help if anyone knows how to do this in...
                                          09-20-2024, 08:10 AM
                                        • maneatingmonkey
                                          Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
                                          by maneatingmonkey
                                          I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
                                          There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
                                          03-27-2024, 07:17 AM
                                        • karlp028
                                          MSI Z390-A PRO missing VCORE voltages
                                          by karlp028
                                          I've got an MSI Z390-A Pro motherboard that starts up fine, but it's missing the VCORE (and VGT) voltages. All of the other voltages are present (e.g. VCCSA, VCCIO) and I know the CPU (i7-9700k) is good. Now, the original PWM controller (UP9521P) had an internal short and I replaced it with a new one. All of the enable signals look good. The problem seems to be the PWM signals going to the MOSFET drivers. I checked them with an oscilloscope and they are all flat 1.5V with no pulses. I don't know why this would be and I'm not sure where to look next.
                                          06-23-2025, 01:25 AM
