No HDMI output Acer DH5JV LA-G021P
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    Hi good day to all thi acer lapotp dont have lcd connect becasue the bracket got broken , so other way is to use a hdmi output 2 weeks after the unit wont display in hdmi mode but when I just use its own lcd it will show display but plugging the connectoor at the same time nothings display in the hdmi outpu.
    I hope someone has the same I issue .
    Can this be a bios probllem?
    [MOD EDIT] Link to schematic -> https://www.badcaps.net/forum/troubl...se#post1620415
  • R_J
    • 9535
    Re: No HDMI output Acer DH5JV LA-G021P
    Have you tried using the Fn + F5 keys to switch the output to external display?
    • kalilinux25
      • Mar 2018
      • 2089
      • ZAMBOANGA SIBUGAY
      yes sir then I tried also to remove the lvds connector just using the hmdi output no display
      • stingerchamp
        • Sep 2020
        • 425
        • Pakistan
        +5vs is coming as input for u74
        Converting it into +5vsdisplay at hdmi connector
        Check u74 pins1,2,3 voltage
        Check hdmi connector pins 15,16,17,18 voltage
        Check u1302 inputs +3vs and +5valw coming
        Then check its output hdmi_1.2 for display
        • kalilinux25
          • Mar 2018
          • 2089
          • ZAMBOANGA SIBUGAY
          u74 has 5vs in display pin 2 to ground pin 3 has 5v
          • stingerchamp
            • Sep 2020
            • 425
            • Pakistan
            You did not check other voltages
            Hdmi connector and u1302
            If you check at one side and do not check other side
            You will not find fault
            So always check end to end
            • Jayanta
              Acer Nitro 5 AN515-55 no HDMI output.
              by Jayanta
              Hello, forum people.
              I have an Acer Nitro 5
              Model Number: AN515-55 Part Number: NH.Q7NSI.001
              Motherboard: Compal GH51M LA-K861P Rev 1A with 1650 Ti graphics.
              My laptop was working fine until I made a grave mistake of changing the thermal pad and paste because my laptop was getting old and pretty hot. After changing and successfully testing temperatures, I was shocked when I tried to connect my external display, a 1440p 75Hz monitor, to it. My display never showed up; it always said 'no signal.' I tried swapping the HDMI cable, using both source 1 and 2 on...
              06-17-2024, 02:49 AM
            • budwich
              ESD Diode on HDMI output of Yamaha a1050 RCVR
              by budwich
              I lost one of the two hdmi outputs on a yamaha rx-a1050 receiver. Of course, it is the hdmi1 which has the arc capability which was useful. The second output hdmi works OK.
              I got an hdmi breakout board which gave me access to the "little guys" in the hdmi. I did some gross DC voltage measurements to ground and found that the Data1 pair (4 and 6) had a lower voltage than the working hdmi.... 1.1v versus 2.9. All others pins seem to be OK. Further when plugged into a display, there is no video but a message on the screen which I assume is the display's status for the...
              09-11-2023, 12:21 PM
              09-06-2024, 05:27 AM
            • amigo744
              ps5 cfi-1016a hdmi output graphics glitches ???
              by amigo744
              i have a ps5 here, which only produces graphic artefacts on the screen when the console shuts down.
              no graphic artefacts visible in ps4 and ps5 games.
              when the console is started, no artefacts can be seen in the main menu!
              It's all very strange and I don't know what to do next
              I swapped the hdmi port, no change.
              could it be the hdmi encoder or the components near the hdmi ports?
              how are the hdmi filters checked for functionality?
              https://youtu.be/cOCapeDOMZk
              Have anybody here same problem with hdmi...
              08-11-2023, 05:42 AM
            • Prosatanosz
              Asus B85M-GAMER no hdmi output and random restarts
              by Prosatanosz
              Hi!
              Asus B85M-GAMER absolute no hdmi output (not at start, not at Windows), and random restarts. Everything work, except hdmi and random restarts after 0.1-3 min. Restarts even in bios. On VGA Windows boots up fast, games and apps starts ok. Mem, psu, cpu changed, no luck. I need shematic, because i think the restarts caused by the hdmi failure.
              10-19-2024, 05:27 AM
