No HDMI output Acer DH5JV LA-G021P
    Hi good day to all thi acer lapotp dont have lcd connect becasue the bracket got broken , so other way is to use a hdmi output 2 weeks after the unit wont display in hdmi mode but when I just use its own lcd it will show display but plugging the connectoor at the same time nothings display in the hdmi outpu.
    I hope someone has the same I issue .
    Can this be a bios probllem?
    [MOD EDIT] Link to schematic -> https://www.badcaps.net/forum/troubl...se#post1620415
    Re: No HDMI output Acer DH5JV LA-G021P
    Have you tried using the Fn + F5 keys to switch the output to external display?
      yes sir then I tried also to remove the lvds connector just using the hmdi output no display
        +5vs is coming as input for u74
        Converting it into +5vsdisplay at hdmi connector
        Check u74 pins1,2,3 voltage
        Check hdmi connector pins 15,16,17,18 voltage
        Check u1302 inputs +3vs and +5valw coming
        Then check its output hdmi_1.2 for display
          u74 has 5vs in display pin 2 to ground pin 3 has 5v
            You did not check other voltages
            Hdmi connector and u1302
            If you check at one side and do not check other side
            You will not find fault
            So always check end to end
