820-00165 "No Camera detected"
  • ligym60
    • Oct 2016
    • 39
    Hi I have a 2- 820-00165 with the same issue No camera detected
    History: Both had water damage around SMC. both when i got them had no green light. repaired a few blown resistors and traces. everything works
    except
    Camera
    "No Camera Detected"
    1) I inspected the connector pins J4002 for continuity to inside pins i also checked for pin clearance. Replace the entire cable and camera/ALS cable including new camera module. Still the same issue. Checked all the filters going to j4002 and voltages.
    2) I cleaned ME region Twice with no change.
    3)I replaced u3900"BCM15700A2KFEB4G" the one good thing is that now the ALS circuit is working. So by covering the eye of the sensor the keyboard is illuminating
    My next step is to set up my Oscilloscope
    I have tested these lines Below and as of last the CLK/DATA was all over the place.
    The issue can be my O'scope is only 100mhz these lines might be out of range since it says mipi is .7-2ghz as for the I2C/smbus I will try using Serial Bus Decoder on the scope to see if i see any data/clock.
    I'm going to test J4002 for all these signals To see if anythings changed. if anyone has experienced this issue Please throw me a bone
    MIPI_CLK_CONN_N
    MIPI_CLK_CONN_P
    MIPI_DATA_CONN_N
    MIPI_DATA_CONN_P
    SMBUS_SMC_1_S0_SDA
    SMBUS_SMC_1_S0_SCL
    I2C_CAM_SCK
    I2C_CAM_SDA
    PP5V_S3RS0_ALSCAM_F
  • piernov
    • Jan 2016
    • 4437
    • France
    Re: 820-00165 "No Camera detected"
    You should try under Linux, the driver puts out pretty verbose kernel debug message and it could help narrowing down the problem.
    • ligym60
      • Oct 2016
      • 39
      Thank you will give it a go under linux
      • ligym60
        • Oct 2016
        • 39
        Hey @piernov I didnt see any errors in verbose. I tried $lspci and $lsmod to see if i can find the camera listed but I found none.
        • piernov
          • Jan 2016
          • 4437
          • France
          Under `lspci` a "Multimedia controller" with "Broadcom" in the name should show up (not the "Network controller" which is the WiFi card), it's the camera controller IC U3900 and it's connected to the PCH through a PCIe bus. The camera itself is connected to U3900 through a MIPI bus.
          Under Linux you have to install this driver manually: https://github.com/patjak/bcwc_pcie
          But if you don't even have the Broadcom Multimedia controller under lspci then installing this driver is pointless (it won't trigger so no message will be shown).
          Are you sure U3900 is soldered properly? Do a thorough visual inspection near it to make sure there's no missing caps/resistors.
          I still attach a picture of what the kernel log looks like when loading the facetimehd driver.
          • ligym60
            • Oct 2016
            • 39
            No, I didn't see the multi media controller " Broadcom" only network controller with lspci it didn't show
            I inspected u3900 under a microscope again but its very tight with the board. These chips I bought from a china I ordered 3 of them. I have 2 boards with the same exact issue and both had water damage around SMC chip. Before I replace u3900 i'd like to trace from PCH to u3900 and from u3900 to camera. Since I've already done this with DMM. Do you think Probing signals with O'scope would help? Thank you @piernov for your help
            • zpi
              • Feb 2018
              • 132
              • Lithuania
              Hello guys, when i have this problem and all voltages for u3900 input is present %90 changing u3900 solves problem (offcourse first cheking main voltages and coils.
              • piernov
                • Jan 2016
                • 4437
                • France
                Yes indeed but U3900 was already replaced here.
                But as you said power rails on U3900 should be checked as well. It uses a 3.3V input and generates a bunch of other power rails.
                • ligym60
                  • Oct 2016
                  • 39
                  hello everyone I'm sorry for the slow response I've been working on other things:
                  I retested these signals today
                  PP0V675_MEM_CAM_VREFCA=.675V
                  PP0V675_CAM_VREF=.0V
                  PP1V8_CAM= 1.79V
                  PP1V2_CAM= 1.2V
                  PP1V35_CAM=1,34V
                  PP3V3_S3RS_CAMERA=3.3V
                  CAM_SENSOR_WAKE_L=0V
                  CAM_PWR_SEL=.5V
                  CAMERA_PWR_EN=3.3V
                  CAM_TEST_OUT=0V
                  PCIE_WAKE_L=3.3V
                  SYSCLK_CLK25M_CAMERA=25M
                  Test with oscilloscope
                  i wasn't able to get the air on screen to activate camera on osx i think my thunderbolt adapter is acting up :/
                  Thank you for your help and continued support
                  • ligym60
                    • Oct 2016
                    • 39
                    @piernov Hi I rechecked the power rails and it seems that all are up and running. I still question the clk as it is unstable sometimes reading good other times not. I have a few u1900 chips i was thinking of replacing it before trying another u3900. I figured I'd ask before sacrificing another chip. Have i missed something? any other thoughts before i proceed?
                    Thank you
                    • ligym60
                      • Oct 2016
                      • 39
                      It's Fixed resolved clk issue. reflow and its done.
                      • kjchatman
                        • Dec 2012
                        • 208
                        • united states
                        what was reflowed?
                        • tlough75
                          • Apr 2017
                          • 33
                          • US
                          What temps did you use? I have an 820-00165 with a shorted U3900, would like to try to change just for fun. I already sold the customer a replacement board with working U3900 so they gave me the old one.
