Hi I have a 2- 820-00165 with the same issue No camera detected
History: Both had water damage around SMC. both when i got them had no green light. repaired a few blown resistors and traces. everything works
except
Camera
"No Camera Detected"
1) I inspected the connector pins J4002 for continuity to inside pins i also checked for pin clearance. Replace the entire cable and camera/ALS cable including new camera module. Still the same issue. Checked all the filters going to j4002 and voltages.
2) I cleaned ME region Twice with no change.
3)I replaced u3900"BCM15700A2KFEB4G" the one good thing is that now the ALS circuit is working. So by covering the eye of the sensor the keyboard is illuminating
My next step is to set up my Oscilloscope
I have tested these lines Below and as of last the CLK/DATA was all over the place.
The issue can be my O'scope is only 100mhz these lines might be out of range since it says mipi is .7-2ghz as for the I2C/smbus I will try using Serial Bus Decoder on the scope to see if i see any data/clock.
I'm going to test J4002 for all these signals To see if anythings changed. if anyone has experienced this issue Please throw me a bone
MIPI_CLK_CONN_N
MIPI_CLK_CONN_P
MIPI_DATA_CONN_N
MIPI_DATA_CONN_P
SMBUS_SMC_1_S0_SDA
SMBUS_SMC_1_S0_SCL
I2C_CAM_SCK
I2C_CAM_SDA
PP5V_S3RS0_ALSCAM_F
except
Camera
 MIPI_CLK_CONN_N
MIPI_CLK_CONN_P
MIPI_DATA_CONN_N
MIPI_DATA_CONN_P
SMBUS_SMC_1_S0_SDA
SMBUS_SMC_1_S0_SCL
I2C_CAM_SCK
I2C_CAM_SDA
PP5V_S3RS0_ALSCAM_F
