Asus V555U power On problem
  • salawayon
    • Nov 2012
    • 568
    • philippines
    Board info:
    ASUS X555UJ
    REV: 2.0
    this unit won't power ON when using AC Adapter only but with good battery it will power up. when i reheated the area where the PQ8906/PQ8907 located it power up but for a short period of time only. i tried already replacing BQ24780s charging IC but the status still the same... for now i put back the original BQ24780s...
    Data at BQ24780s:
    Charging IC - BQ24780S
    1 P CHG ACN 10 = 0.004VDC
    2 P CHG ACP 10 = 0.004VDC
    3 P CHG CMSRC 20 = 0.035VDC
    4 P CHG ACDRV 20 = 0.001VDC
    5 P CHG ACOK 10 = 0VDC
    6 P CHG ACDET 10 = 2.66VDC
    7 P CHG IADP 10 = 0003VDC
    8 P CHG IDCHG 10 = 0VDC
    9 P IMVP8 PSYS INFO = 0VDC
    10 P CHG PROCHOT# 10 = 0VDC
    11 P CHG SDA 10 = 0VDC
    12 P CHG SCL 10 = 0VDC
    13 P CHG CMPIN 10 = 0VDC
    14 P CHG CMPOUT 10 = 0VDC
    15 P CHG BATPRES# 10 = 0VDC
    16 P CHG TB STAT# 10 = 0VDC
    17 P CHG BATSRC 20 = 0.155VDC
    18 P CHG BATDRV 20 = 0.048VDC
    19 P CHG SRN 10 = 0.155VDC
    20 P CHG SRP 10 = 0.155VDC
    21 P CHG ILIM 10 = 0VDC
    22 GND
    23 P CHG LG 30 = 0VDC
    24 P CHD REGN 20 = 6.09VDC
    25 P CHG BST 30 = 5.99VDC
    26 P CHG HG 30 = 0.155VDC
    27 P CHG LX 30 = 0.155VDC
    28 P CHG VCC 20 = 19.42VDC
    thanks...
  • Sephir0th
    • Oct 2020
    • 1282
    Re: Asus V555U power On problem
    ACDRV Drives the DC-IN Mosfets. The Signal isn't Coming Out and we have to find Out why. What about the DC-IN Mosfets. Did you already Tested them for internal short? Where Stops the Voltage? Check for Short to ground too.
    FairRepair on YouTube
    • stingerchamp
      • Sep 2020
      • 425
      • Pakistan
      I did not understand 10, 20,30???
      No voltage on CLR point, 19v missing
      Prochat is 0 , adapter is bad or insufficient current
      Batpress is active but SDA scl 0v
      Pq8907 DC in MOSFETs?
      Share schematic
      Replace adapter if laptop start with battery only
      Readings are not normal
        • 20848
        Share schematic
        Boardview - https://www.badcaps.net/forum/showpo...04&postcount=5
        • salawayon
          • Nov 2012
          • 568
          • philippines
          Share schematic
          sorry, adapter is not an issue... tried adapters with ratings like 19v 3.42a and 19v 9.23a... and sorry i don't have schematics for this unit.. i only use boardview as my guide... so far i can't find any short circuit on this board... data that i wrote here were all what i got with my multimeter readings. right after PQ8906 is 0vdc...
          PQ8907 = 0vdc on any pins.
          for 10,20,30 things.. please see attached... i just wrote what i saw on boardview...
          thanks...
          • salawayon
            • Nov 2012
            • 568
            • philippines
            BTW, the moment i plug-in the adapter, Power On LED blinks 7times with around 1second interval and it goes off totally...
            • stingerchamp
              • Sep 2020
              • 425
              • Pakistan
              First try
              Hard reset by removing CMOS for 30min and hold down power button for 30 sec
              Second check
              https://www.asus.com/support/FAQ/1030642/
              Third check DC Jack connector
              Adapter is changing but DC Jack cable is same
              • salawayon
                • Nov 2012
                • 568
                • philippines
                First try
                Second check
                thank you for your inputs...
                First:
                on this unit i can't find any CMOS BATTERY to disable. and the motherboard been separated from any power source or battery for a month.
                second:
                the link given was for router for a rescue or recovery...
                third:
                i'll give it a try..
                • salawayon
                  • Nov 2012
                  • 568
                  • philippines
                  changing DC JACK doesn't solve the problem. but reheating/reflowing all components (mosfets, resistors, capacitors and others) after DC JACK had solved the problem... it been running for 12hrs. and tried already reinstalling OS three times... but one more problem on this unit, NVIDIA 940mx chipset had error code 43. tried already installing NVIDIA drivers via driverpack and from NVIDIA support site.
                  • stingerchamp
                    • Sep 2020
                    • 425
                    • Pakistan
                    https://support.microsoft.com/en-us/...e-0c6190502842
                    Try update via device manager
                    • Sephir0th
                      • Oct 2020
                      • 1282
                      Did you flashed BIOS via Programmer before Sharing your Case here? I Challenged similar issue causing "wrong" BIOS flashed.
                      • GLISIT
                        by GLISIT
                        01-16-2025, 02:29 PM
                      • PantherDave
                        by PantherDave
                        Hi all!
                        05-29-2024, 02:01 PM
                      • ShadowAi
                        ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
                        by ShadowAi
                        Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
                        Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
                        After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
                        03-15-2024, 10:46 AM
                      • meraklinetx
                        Asus Z97-a power cycle, no boot no cpu voltage
                        by meraklinetx
                        Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                        05-10-2023, 06:08 AM
