HP 250 g1 capslock blinking
  • nassih
    • Oct 2015
    • 280
    • morocco
    hi everyone
    HP 250 g1 caps lock blinking 3 time no picture no backlight FAN spin ok
    i have flashed bios main and bios EC,cheeking RAM seem problem.
    tanks
  • fauzanmint
    • Jun 2018
    • 82
    • Indonesia
    Re: HP 250 g1 capslock blinking
    try enother ram
    • nassih
      • Oct 2015
      • 280
      • morocco
      after flashing with another bios file i have no blink on caps lock but still the same problem no graphics no backlight.
      all coils have voltage except L6710 ( PVAXG )0v.
      any suggestion,tanks
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        This is a common fault on this mb-GFX core missing. Most of the times its bios but in some cases its PCH fault. DRAMRST# on pin30 of ram slot is present???
        • nassih
          • Oct 2015
          • 280
          • morocco
          tanks sir i will try this and tell you after
          • nassih
            • Oct 2015
            • 280
            • morocco
            Dramrst pin 30 slot1 0.81v, slot2 0.78v
            • stingerchamp
              • Sep 2020
              • 425
              • Pakistan
              Dramrst must be equal to your ram voltage
              For ddr3 1.5v
              For DDR3L. 1.35v
              DDR4. 1.2v
              Dramrst is not ok
              • nassih
                • Oct 2015
                • 280
                • morocco
                where Dramrst coming from?i have 1.5v on ram slot
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  Check voltage on Q539
                  • nassih
                    • Oct 2015
                    • 280
                    • morocco
                    Q539 voltage measured on pins : 3.3V; 1.5V ;1.5V
                    • mkdj
                      What should I do after having flashed a BIOS?
                      by mkdj
                      Dear all,
                      I did my first laptop repair related to a BIOS issue. Laptop is a Lenovo ThinkPad T480, and was not booting. With my brand new programmer, I did a back-up of the current not working BIOS, erased the BIOS chip, and flashed this dump: https://www.badcaps.net/forum/troubl...83#post3686683
                      Now the laptop works fine, I can access BIOS and boot on a USB drive. But I read stuff about DMI, and...
                      09-09-2025, 09:45 AM
                    • Loli Popu
                      DELL 5590 LAPTOP DEAD AFTER BIOS WRONG FLASHED
                      by Loli Popu
                      Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
                      12-13-2024, 03:28 AM
                    • drux
                      Alienware Aurora R15 accidentally flashed with XPS 8960 BIOS
                      by drux
                      I've had an ssd that was previously used on dell xps 8960 and then it was installed in Alienware Aurora R15(intel version). On first windows boot in R15 windows started bios update and loaded bios for xps 8960(r15 and xps8960 essentially have same motherboards).
                      Now it has xps 8960 bios that looks different from alienware bios and when I'm trying to run bios update files for R15, I get unsupported platform error.
                      These models have AMI/Aptio BIOS.
                      Tried to edit product info with DMI Edit to change values back to Alienware R15, but it does not want...
                      11-03-2024, 01:18 AM
                    • sssssssssssssss
                      Need BIOS for HP Pavilion 15-n058sr recovery - Caps Lock blinking twice
                      by sssssssssssssss
                      I'm dealing with a classic BIOS corruption issue on an HP Pavilion 15-n058sr and hoping someone here might have the original BIOS file or point me in the right direction.
                      Symptoms:
                      • Laptop powers on but no display at all (completely black screen)
                      • Caps Lock blinks twice with a pause, then repeats continuously
                      • F12 LED stays on permanently
                      • No POST, no boot sequence, nothing on screen
                      Based on HP diagnostic codes, the 2-blink Caps Lock pattern indicates BIOS corruption/failure.
                      What I've tried:
                      • Hardware reset (battery removal, power
                      09-04-2025, 06:45 AM
                    • zenius
                      by zenius
                      12-08-2024, 06:13 AM
