Short on motherboard power rail - general question
  • Askic
    • Sep 2018
    • 187
    • BIH
    Hello guys,
    first of all I'm not a professional in repairing electronics, but I do have formal electrical background. From time to time I have managed to repair something like PSU or laptops when faults were obvious or very easy to find with a multimeter.
    However, recently I had a problem with 19V power rail shorted to ground. I was not able to find the cause, because a shorted component was somewhere deeper in the motherboard and this was handed to a professional.
    I wonder if it is sufficient to check 8th pin on BIOS chip and pin on power switch, where 3.3V is expected and to test it against the ground to conclude that short is not on 3.3V rail?
    Since 3.3V is produced from the main 19V, it is reasonable to assume that short on 3.3V can appear like short of 19V rail.
    Thank you.
  • stingerchamp
    • Sep 2020
    • 425
    • Pakistan
    Re: Short on motherboard power rail - general question
    First of all , you don't have to be professional to understand gate , voltage or any signal processing
    You need basic understanding of MOSFET, signals , resistor, capacitor, and basic motherboard voltage level processing etc.
    Read basic tutorial given in this forum and you will understand
    19v is connected to all linear drive ic, switch ICS and all other etc. The main point where it is going out in motherboard from DC in section or charger ic section in general is a CLR , current limiting resistor.
    Remove it and check resistance to ground on CSP and CSN
    This will give you idea if short is on DC in MOSFETs side or 19v out or edge side.
    Read guide you will understand.
    Short can be due to vin section as it is spreading in motherboard.
    • Askic
      • Sep 2018
      • 187
      • BIH
      Hello stingerchamp and thank you for your reply. Can you post a link to the tutorial you meant? I have read the basic guidelines here.
      • stingerchamp
        • Sep 2020
        • 425
        • Pakistan
        Yes same tutorial but CLR info is not mentioned instead DC in section is mentioned, CLR is part of DC in section.
        If you have any question , you can write, I will answer
        • stingerchamp
          • Sep 2020
          • 425
          • Pakistan
          Originally posted by Askic
          Hello guys,
          Thank you.
          first step make sure 19v available in motherboard
          Second step make sure 3v ic ldo is generated
          Short on 3v does not mean there must be fault on 19v
          • Askic
            • Sep 2018
            • 187
            • BIH
            Hello stingerchamp, even after reading the beginner guidelines again, I'm not sure what CSP and CSN are since these abbreviations are not mentioned in the text.
            However I hope you'll be able to show me on the real world example. Recently, I have successfully repaired motherboard by sheer luck because faulty (shorted) cap had black marks and was short to ground. When I removed this cap everything worked OK.
            Here on the attached picture one can see charging port connector and battery connector.
            Can you please tell me what is the CRL in this picture?
            I know that CSP and CSN are probably outputs from IC battery charger chip.
            I assume that this IC is on the other side of the board and that CLR is actually R889.
            • stingerchamp
              • Sep 2020
              • 425
              • Pakistan
              It is in every motherboard
              It is just a name of pads of a current limiting resistor or power resistor
              Current sense positive csip
              Current sense negative csin
              These are pins 1,2 of a charging ic through which
              Charging ic check correct current sensed or not
              • Askic
                • Sep 2018
                • 187
                • BIH
                Ok thank you. so these two pins are labeled ACP and ACN on the schematics you attached. I understand now.
                • grimacelord
                  Xbox One S - 12V Rail Short - Q9F1 Keeps Blowing
                  by grimacelord
                  Have an Xbox One S here that has a short on the 12V power rail. There is no power, beep, or partial fan spin when connecting power cable.
                  After diagnosing with thermal camera, Q9F1 MOSFET (NTTFS4C50N) is getting hot. When I remove this MOSFET, the short on the 12V rail disappears.
                  I first replaced Q9F1 with one from a donor board and then partially reassembled the Xbox to test. When I plugged the power cord in, I got a partial fan spin and I thought I had fixed it, but unfortunately, the Xbox still did not power on. So I then disassembled the Xbox...
                  10-24-2024, 12:31 PM
                • joshAU
                  Acer AN515-55-528T FH52M LA-J891P - Short ciruit after PQW1 MOSFET on +1.35VSDGPU rail.
                  by joshAU
                  Hi all.
                  This notebook was showing no signs of life.
                  I removed the FH52M LA-J891P mainboard and found that there was 19V at the DC jack.
                  However there was zero volts on the two PRB2 and PRB46 resistors immediately after the two polarity protection MOSFETs (PQB11 & PQB12).
                  If I remove the PQW1 MOSFET, the 19V rail starts working, and I can turn on the unit - at least I get the fans, and the power light comes on, when I simulate the power button being pressed. No display.
                  I tried replacing the MOSFET with a new one, but again no voltage on the...
                  05-29-2024, 12:33 AM
                • worlor
                  MSI GE62 Laptop Motherboard with Short on main power rail
                  by worlor
                  I am currently learning to repair laptop motherboard and I need some advice/help.
                  I have a MSI GE62-6PQ laptop that didn't boot. It's an old laptop that got a glass of coke :/
                  I have cleaned the motherboard with isopropyl alcohol and a brushteeth.
                  The motherboard is a MS-16J51. I put the schematics attached.
                  I also attach high res pictures of the board.
                  Symptoms :
                  When I connect it to the power supply, it goes into protection.
                  What I have done :
                  Checked the fuse : OK
                  Visual check OK : No burned components
                  06-30-2021, 03:50 PM
                • karlp028
                  MSI B360M Bazooka short on 3VSB rail
                  by karlp028
                  I have an MSI B360M Bazooka with a dead short on the 3VSB rail (and VDD33 which is connected). The ethernet controller chip (UL3 in boardview) was getting very hot, so I thought that was the culprit. But after I removed it, the short remained. When I added 5V standby power again, I noticed the ground pad where the ethernet controller had been was getting very hot, as was the nearby hole for an m2 standoff.z
                  I haven't found the problem component(s) causing the short yet (no thermal cam). Does the heating of the ground pad mean it should be something near there?
                  04-01-2025, 07:20 PM
                • gaelican
                  Asus ROG ga401IV motherboard - AC Short Protection resistor getting hot
                  by gaelican
                  I am working on an Asus ROG laptop repair. I was able to find that there is a short on the motherboard, and the 20 volts from the charger only gets to the first mosfet before disappearing.
                  When looking around with a thermal camera, I noticed the chip marked "14C" in the picture was getting warm. Nothing else was receiving heat.
                  I found a boardview diagram and schematic for a motherboard that looks nearly identical, that has the same component. This appears to be marked as "AC Short Protection" with a value of 13.7KOhms.
                  02-21-2025, 01:51 PM
