MSI B360M Bazooka short on 3VSB rail
  • karlp028
    • Jul 2024
    • 23
    I have an MSI B360M Bazooka with a dead short on the 3VSB rail (and VDD33 which is connected). The ethernet controller chip (UL3 in boardview) was getting very hot, so I thought that was the culprit. But after I removed it, the short remained. When I added 5V standby power again, I noticed the ground pad where the ethernet controller had been was getting very hot, as was the nearby hole for an m2 standoff.z
    I haven't found the problem component(s) causing the short yet (no thermal cam). Does the heating of the ground pad mean it should be something near there?
  • FriedFred
    • May 2024
    • 140
    It can also be a short inside a layer of the motherboard.
    Is there any capacitor shorted in this area?
    You can try to find the short with some current injection, use 1V and 200mA and check the capacitors in this area. Maybe a component on the board will get hot.
    But it seems to me, there is a short inside the board or on the other side of the removed component.
    It can be that the Ethernet PHY is not actively shorting something, but is getting shorted from another component afterwards.
    • karlp028
      • Jul 2024
      • 23
      Thanks. I actually found it last night. There was a capacitor next to the chip that looked a little burned on one end. I removed it and now the short is gone. The cap and the chip must share a ground plane which explains why it was getting hot.
      The board works now, except I have to add the LAN chip back. I wish I hadn't removed that.
      • Victor Moreira Silva
        Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
        by Victor Moreira Silva
        I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
        Well, my decice specs are the following:
        Model: Acer Nitro 5 AN517-54-55T5
        CPU: Intel Core i5-11400H
        GPU: NVIDIA GeForce GTX 1650
        Motherboard: GH51G LA-L181P Rev:1c
        The symptom:
        When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
        05-26-2025, 10:49 AM
      • grimacelord
        Xbox One S - 12V Rail Short - Q9F1 Keeps Blowing
        by grimacelord
        Have an Xbox One S here that has a short on the 12V power rail. There is no power, beep, or partial fan spin when connecting power cable.
        After diagnosing with thermal camera, Q9F1 MOSFET (NTTFS4C50N) is getting hot. When I remove this MOSFET, the short on the 12V rail disappears.
        I first replaced Q9F1 with one from a donor board and then partially reassembled the Xbox to test. When I plugged the power cord in, I got a partial fan spin and I thought I had fixed it, but unfortunately, the Xbox still did not power on. So I then disassembled the Xbox...
        10-24-2024, 12:31 PM
      • nagkiller
        Asus Geforce Cerberus GTX1050TI-O4G-DIS short circuit in the FBVDDQ rail
        by nagkiller
        Hello everyone!
        This grafic card came for repair, but when I connected it to the motherboard, the board would not start (short circuit in the 12V rail).
        After removing some PLs to isolate the short in the 12V rail, I got to PML1/PML2, according to the BoardView reference.
        Even injecting a voltage of 1V0 and a current of 3A in the FBVDDQ rail, for example, the voltage drops to 0V20 and none of the components heat up.
        The attached boardview file is very similar to this grafic card, which I am basing the repair on.
        I would like some...
        05-10-2025, 09:19 AM
      • joshAU
        Acer AN515-55-528T FH52M LA-J891P - Short ciruit after PQW1 MOSFET on +1.35VSDGPU rail.
        by joshAU
        Hi all.
        This notebook was showing no signs of life.
        I removed the FH52M LA-J891P mainboard and found that there was 19V at the DC jack.
        However there was zero volts on the two PRB2 and PRB46 resistors immediately after the two polarity protection MOSFETs (PQB11 & PQB12).
        If I remove the PQW1 MOSFET, the 19V rail starts working, and I can turn on the unit - at least I get the fans, and the power light comes on, when I simulate the power button being pressed. No display.
        I tried replacing the MOSFET with a new one, but again no voltage on the...
        05-29-2024, 12:33 AM
      • techrepairheide
        Gaming laptop Clevo NH79EP with short on 5VS-rail
        by techrepairheide
        first of all I want to apologize for my bad English, but I try to give my best.
        Customer brought me a laptop, which is charging the battery (when the dc-jack is connected) but don't power up when the power-button was pressed down. Only the white LED lights up, and you can hear a short noise in same interval when power-button was pressed and hold for longer timer. The customer changed already battery and dc-power-adapter.
        For this laptop the correct shematic is the service manual "Clevo NH50ER NH57ER NH50EPS NH57EPS - 6-71-NH5S0-D02 Schematic"....
        10-13-2024, 02:49 PM
