Lenovo 320 80XH
  • zmeutz
    • Nov 2016
    • 82
    • Romania
    Lenovo 320 80XH
    I have a problem with Lenovo 320 board 80XH, it starts only if I reset bios(pull out battery and bios battery) but after I shut it down it doesn't start again only if I reset it ...
    anyone had this problem?
    I have write bios ic data and ec data from forum, but same situation ...
    thanks!
  • stingerchamp
    • Sep 2020
    • 425
    • Pakistan
    Re: Lenovo 320 80XH
    If you pull out bios battery only and start with both main battery and charger will it start?
    If not then problem is with main battery or adapter in general
    If you start with adapter only and it does it means problem with main battery
    Bios battery voltage must be 3 or greater for laptop to start in normal way, without it laptop will boot at 3rd attempt after restart
    Confirm problem with main battery or not by start only with adapter plugin
    • zmeutz
      • Nov 2016
      • 82
      • Romania
      Re: Lenovo 320 80XH
      ok, tested
      AC connected - bios disconnected / doesn't start
      main battery connected - bios disconnected / doesn't start
      main battery disconnected / ac connected / bios connected - doesn't start
      main battery connected / ac disconnected / bios disconnected - doesn't start
      bios battery voltage / 3.1v
      • stingerchamp
        • Sep 2020
        • 425
        • Pakistan
        Re: Lenovo 320 80XH
        At which state it works?
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Re: Lenovo 320 80XH
          What do you mean by bios disconnected?? Which kbc it uses?? Check RTc section like RTC_RST#/SRTC_RST#. Look for jumper marked on mb "cmos1" or "me1"
          • Wahaz
            by Wahaz
            10-30-2023, 08:42 PM
          • grimacelord
            Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
            by grimacelord
            Hello there.
            I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
            History:
            1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
            I searched for this error online and discovered...
            03-15-2023, 03:29 PM
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
          • BootNewbie
            Lenovo v15 bios corruption! help needed!
            by BootNewbie
            3 days prior my Lenovo laptop notified of a bios update, at first I tried to decline it but when i put it on charging lenovo vantage started installing it automatically. After bios was updated i was asked for ftpm reset, first I chose no but same pop up showed up so i had to choose yes. After this concluded i successfully booted, but i had linux dual booted with windows, and it was nowhere to be seen after bios update, i tried secure boot off then successfully entered linux. after shutting down my laptop i encountered this issue:
            power is supplied
            screen remains blank (it gets...
            Yesterday, 11:37 AM
          • jendkkd jeje
            Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
            by jendkkd jeje
            So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
            I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
            10-11-2024, 03:12 PM
