Lenovo 320 80XH
  • zmeutz
    • Nov 2016
    • 84
    Lenovo 320 80XH
    I have a problem with Lenovo 320 board 80XH, it starts only if I reset bios(pull out battery and bios battery) but after I shut it down it doesn't start again only if I reset it ...
    anyone had this problem?
    I have write bios ic data and ec data from forum, but same situation ...
    thanks!
  • stingerchamp
    • Sep 2020
    • 425
    • Pakistan
    Re: Lenovo 320 80XH
    If you pull out bios battery only and start with both main battery and charger will it start?
    If not then problem is with main battery or adapter in general
    If you start with adapter only and it does it means problem with main battery
    Bios battery voltage must be 3 or greater for laptop to start in normal way, without it laptop will boot at 3rd attempt after restart
    Confirm problem with main battery or not by start only with adapter plugin
    • zmeutz
      • Nov 2016
      • 84
      Re: Lenovo 320 80XH
      ok, tested
      AC connected - bios disconnected / doesn't start
      main battery connected - bios disconnected / doesn't start
      main battery disconnected / ac connected / bios connected - doesn't start
      main battery connected / ac disconnected / bios disconnected - doesn't start
      bios battery voltage / 3.1v
      • stingerchamp
        • Sep 2020
        • 425
        • Pakistan
        Re: Lenovo 320 80XH
        At which state it works?
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Re: Lenovo 320 80XH
          What do you mean by bios disconnected?? Which kbc it uses?? Check RTc section like RTC_RST#/SRTC_RST#. Look for jumper marked on mb "cmos1" or "me1"
          • lucaszmn
            by lucaszmn
            Problem:
            Initial Findings:
            • I concluded that the
            08-12-2025, 03:01 PM
          • Wahaz
            by Wahaz
            10-30-2023, 08:42 PM
          • grimacelord
            by grimacelord
            Hello there.
            History:
            03-15-2023, 03:29 PM
          • mkdj
            Lenovo IdeaPad 3 - Hard Disk not recognized in BIOS
            by mkdj
            Dear all,
            I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
            Here the steps I have taken to fix the laptop:
            - downloaded latest BIOS from Lenovo Website...
            10-18-2025, 03:43 AM
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
