Asus UX303LN rev 2.0 -start without CPU and GPU power
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3577
    • slovakia
    repair ME but it not help
    reflash bios but still the same
    dont have programmet for ITE so im waiting for it
    any hint on this?
    have two board with same problem
  • emestee
    • 228
    Re: Asus UX303LN rev 2.0 -start without CPU and GPU power
    What about the rest of the power rails? Resistances on all the coils? RTC battery?
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3577
      • slovakia
      rtc ok, resistance ok, have 1.0, 3.3 and 5V, have 3.3 on PWRSW
      as i have two board with same symptoms, this must be something similiar for this models
      • stingerchamp
        • Sep 2020
        • 425
        • Pakistan
        Check ram section voltage
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3577
          • slovakia
          no voltage
          • bruno504
            • Apr 2014
            • 6
            • Portugal
            Any news on this problem?
            • GLISIT
              by GLISIT
              01-16-2025, 02:29 PM
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • PantherDave
              by PantherDave
              Hi all!
              05-29-2024, 02:01 PM
            • ShadowAi
              ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
              by ShadowAi
              Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
              Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
              After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
              03-15-2024, 10:46 AM
            • meraklinetx
              Asus Z97-a power cycle, no boot no cpu voltage
              by meraklinetx
              Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
              05-10-2023, 06:08 AM
