Dell 1564 does not charge battery
  • pippo_one
    • Aug 2010
    • 115
    • Vicenza
    Re: Dell 1564 does not charge battery
    I unsoldered the capacitor Pc97, the component is good but on the mainb in the component pitches the tester marks me short with the ground, so the pin 21 of the PU5 ic has a short that goes to ground
    • pippo_one
      • Aug 2010
      • 115
      • Vicenza
      I am increasingly convinced that the problem is PU5, the short comes from within. I tried to look for this component online, but unfortunately they changed case
      some one help me to find this component?
      • HTR-Informatique
        Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
        by HTR-Informatique
        YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
        I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
        On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
        I also changed the screen because the PC fell and the screen was broken.
        I changed the battery with a new and original battery.
        I also had corrosion/oxidation on the...
        02-09-2025, 06:51 AM
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • razenxd
        How can I charge that battery pack?
        by razenxd
        it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
        At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
        Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
        Now, I have noticed a few things.
        The "dead" battery, while connected to charger and NOT Charging will...
        12-05-2024, 06:11 AM
      • ruletero
        Acer a515-43 low battery charge voltage
        by ruletero
        Hi
        Acer A515-43
        LA-H801P
        Fail: Does not charge battery, has low voltaje on connector.
        Laptop didn't want to turn on, only charge led blinked.
        I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
        I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
        Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
        10-24-2022, 02:31 PM
      • MahmoudNasser
        Dell Vostro 3400 battery does not charge beyond 55%
        by MahmoudNasser
        I have a Dell Vostro 3400 battery does not charge beyond 55%
        I tried another file... the battery charge exceeded 55%, but it entered manufacturing mode and it did not count from it.
        - I rebuilt the basic BIOS and Clear Me, but without results
        What if the same situation does not charge the battery more than 55%?
        Can someone help me?
        The original BIOS file is attached
        Device Data
        Model Dell Vostro 3400
        CPU:i5-11th
        SN 7G4BRF3
        MP PartNumper:LA-K032P REV 1.0 (A00)
        Bios Chips:XM25QH64A...
        10-09-2023, 03:58 PM
