820-2914-B Macbook EFI reset to wipe password, now no power??
  • drnict61
    Nic’s Fix
    • Dec 2020
    • 7
    Greetings! I got a 17" Macbook Pro that I tried resetting the EFI password on. The computer still turned on and charged.
    I was able to read and verify three dumps from the EFI chip, then I modified it removing the two $SVS sections and flashed it to the chip successfully.
    Now the laptop won't show any lights on the charger, or the battery status lights, and nothing happens when I try to turn it on.
    I did not remove the EFI chip from the board when doing my work. I followed this guide: Mac EFI Password Removal (Github)
    What did I do : ( What do I do now? I'm willing to dig in with a multimeter, fine tip soldering iron, and micro heat gun
    I've attached the original and my modified bins.
    Thank you!
    Machine Info: A1297 Macbook Pro 2011 i7, board 820-2914-B, EFI chip Micron 25Q064A
  • zpi
    • Feb 2018
    • 132
    • Lithuania
    Re: 820-2914-B Macbook EFI reset to wipe password, now no power??
    i delete only first $svs block, also perform pram reset on first start after reflashing bios.
    • drnict61
      Nic’s Fix
      • Dec 2020
      • 7
      Thanks for the reply; Unfortunately I just tried only replacing the first instance of $SVS from the bin, verifying every read and flash along the way with md5sum. Still, no signs of life on the laptop or charger
      • qayyum786
        • Aug 2018
        • 1959
        • INDIA
        1st) in case you use jumper method than check voltage on pin no 8 if it is present (if jumper method went wrong can be cause to dead)
        2nd) if you have make backup of original dump before flashing than you may try the original backup and check if laptop back to the life
        • piernov
          • Jan 2016
          • 4439
          • France
          Magsafe LED is completely unrelated with SPI ROM.
          • zpi
            • Feb 2018
            • 132
            • Lithuania
            Measure pp3v42_g3h when magsafe connected, also check sys_onewire
            • drnict61
              Nic’s Fix
              • Dec 2020
              • 7
              pp3v42_g3h measured at c5750 and c5755 and c6908 0.0v
              sys_onewire measured at r6929 0.0v
              doesnt seem to change with any combination of magsafe + battery
              • zpi
                • Feb 2018
                • 132
                • Lithuania
                So your problem pp3v42_g3h, it is first rail to power up after dc in rails. Measure U6990 pin7, pin4 only with MagSafe connected. Also measure resistance to ground on L6995 without charger.
                • drnict61
                  Nic’s Fix
                  • Dec 2020
                  • 7
                  U6990 measured 16.8v
                  L6995 w/o charger multimeter beeped at me on both sides of the inductor
                  Inductor bad?
                  Tysm
                  • zpi
                    • Feb 2018
                    • 132
                    • Lithuania
                    Inductor never goes bad . You have short on your pp3v42_g3h rail.
                    Do you have lab power supply ? If no, you have to lift one side of L6995 and measure resistance to ground in ohms on both sides, only one will show low ohms, let me know which one.
                    • drnict61
                      Nic’s Fix
                      • Dec 2020
                      • 7
                      Lifting it! Pin 2 beeps, nothing on pin 1 : )
                      • zpi
                        • Feb 2018
                        • 132
                        • Lithuania
                        Ok, so something is shorting on output of pp3v42_g3h, you have to inject 1-2volts in L6995 pin 2 (probably will be some capacitor) and try to find hotspot. You also can open boardview (i assume you have it) and inspect all places where pp3v42_g3h goes.
                        • volinakis
                          MacBook Air M1 reset user password
                          by volinakis
                          So ... MacBook Air M1 A2337, entered in Recovery, connected to net, open Terminal -resetpassword, asked to deactivate Mac, deactivated then I was able to set another password. After restart, it asked to activate Mac by selecting admin user and type password but typing new password it doesn't work.
                          I know I can erase Mac and reinstall but client wants to save some files - I know him, is his own laptop brought from shop, he has invoice and all, Apple client service says it can't be done if he didn't save files in iCloud.
                          Any help will be much appreciated, thank you!
                          LE:...
                          10-10-2023, 06:36 AM
                        • ch.wa
                          BIOS password reset for HP ProOne 440 G9
                          by ch.wa
                          HI,
                          I have a problem with the BIOS password for the HP ProOne 440 G9 (AIO). Once I want to enter the BIOS a password is requested (see screenshot) and I am a little unsure if it would be smart to try a wrong password three times (as some people mentioned online) to get a code - I don't want to block the whole system (not sure if that could happen?!). According to other sources a reset is (maybe) not even possible for this model.
                          Any ideas if this may work? Hope someone could help.
                          Thanks for your time!
                          Chris
                          Today, 01:28 PM
                        • ritalo
                          MacBook Air 13 2014 - Remove EFI password
                          by ritalo
                          I have a MacBook Air 13 inches 2014.
                          I have set a EFI password and I can't remember it : now I want to reinstall macOS and I can't because the MacBook is asking for the password.
                          I know how to remove the password with a usb programmer.
                          I plug the usb programmer to the motherboard and to my pc with usb, I read the EFI and I save it to a file.
                          Then I have to find this value in the file : $SVS because it indicate where is the password.
                          But I can't find the value.
                          I have attached the file​
                          Thank...
                          05-14-2024, 12:10 PM
                        • Danielreinaa
                          HELP need password bios Macbook A1706
                          by Danielreinaa
                          Hola chicos, espero estén bien, he estado buscando información para aprender a hacer eliminación de password EFI en macbooks.
                          Actualmente tengo un problema con una macbook pro A1706 820-00923 SN:C02VD3GJHV2Q
                          Si podrian ayudarme les agradeceria mucho o algun link para aprender a hacerlo y no volver a molestarles.
                          gracias de antemano y que tengan una linda tarde, disculpen si estoy rompiendo alguna norma.
                          Hi guys, I hope you are doing well, I have been looking for information to learn how to remove the EFI password on macbooks.
                          09-07-2024, 03:47 PM
                        • namelemen32
                          HP Compaq dx6120 BIOS password reset
                          by namelemen32
                          I have HP Compaq dx6120 i need to reset my bios password.I tried some methods like using CMOS button but it did not work so my last chance is using SMC.bin.
                          Serial Number : SAA62408WR
                          P/N: EC893ES#ABV
                          08-25-2025, 07:37 AM
