No Power output voltage 3v from VIN
+ More Options
Posts
  • kalilinux25
    • Mar 2018
    • 2069
    • ZAMBOANGA SIBUGAY
    Hi good day to all, I have a problem with this unit DAZAAMB16E0 REV E from PQ22 pin 1 I only have 3v , im not good at board that doesnt have schematic and this problem is not common to me. Hope someone can help me .
  • mielta
    • Apr 2015
    • 368
    Re: No Power output voltage 3v from VIN
    Hi
    messure the resistance from pq22 pin1 to ground
    • emestee
      • 228
      https://drive.google.com/file/d/1NsM...lNLY-gOgi/view
      Isn't this the board?
      • kalilinux25
        • Mar 2018
        • 2069
        • ZAMBOANGA SIBUGAY
        Originally posted by emestee
        good sir thanks for shring the schematic
        • emestee
          • 228
          Took me literally 15 seconds in google
          • stingerchamp
            • Sep 2020
            • 425
            • Pakistan
            Pq22 is a deplition type mosfet ,n channel
            So it is always on until there is some short in line
            First we should have either 25 voltage in normal case at source and in case some issue it should go to full zero.
            Measure voltage on gate
            Verify voltage on all pins of charging ic and check pq22 for short
            • piernov
              • Jan 2016
              • 4435
              • France
              I think it's an error in the symbol. It doesn't make sense to use depletion mode MOSFET here, and they are also never used in practice, it's always enhancement mode. It needs 25V on its gate to turn on.
              • kalilinux25
                • Mar 2018
                • 2069
                • ZAMBOANGA SIBUGAY
                I already change the pq 22 and the charger IC , I already burned 3x of ic and in the 4th it work bad soldering tehcnique , thanks to all and the scheamtic great help
                • kalilinux25
                  • Mar 2018
                  • 2069
                  • ZAMBOANGA SIBUGAY
                  Update it wont power again
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    measure Voltage on pin 1/2/3/4/5/6/24/28 of PU5. Replace PC136 with exact same value.
                    • kalilinux25
                      • Mar 2018
                      • 2069
                      • ZAMBOANGA SIBUGAY
                      Originally posted by stingerchamp
                      pq22 is a deplition type mosfet ,n channel
                      so it is always on until there is some short in line
                      first we should have either 25 voltage in normal case at source and in case some issue it should go to full zero.
                      verify voltage on all pins of charging ic and check pq22 for short
                      pin1 acn- 0v
                      pin2 acp - 0v
                      pin3 cmsrc - 0v
                      pin4 acdrv -0v
                      pin 5 acok - 0v
                      pin 6 acdet -1v
                      pin7 iadp - 0v
                      pin 8 - 0v
                      pin9 - 0v
                      pin 10 -0v
                      pin 11-0v
                      pin12-0v
                      pin13-0v
                      pin14-0v
                      pin 15-27-0v
                      pin28- 19v
                      • kalilinux25
                        • Mar 2018
                        • 2069
                        • ZAMBOANGA SIBUGAY
                        pin1 acn- 0v
                        pin2 acp - 0v
                        pin3 cmsrc - 0v
                        pin4 acdrv -0v
                        pin 5 acok - 0v
                        pin 6 acdet -1v
                        pin7 iadp - 0v
                        pin 8 - 0v
                        pin9 - 0v
                        pin 10 -0v
                        pin 11-0v
                        pin12-0v
                        pin13-0v
                        pin14-0v
                        pin 15-27-0v
                        pin28- 19v
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          Not very convinced with your readings. Seems IC pins are not soldered properly. Look under a microscope or atleast a magnifying glass.
                          • kalilinux25
                            • Mar 2018
                            • 2069
                            • ZAMBOANGA SIBUGAY
                            All pins is soldered properly sir
                            • mcplslg123
                              • Jun 2015
                              • 7262
                              • india
                              PR168(866K) & PR3(137K) forms the divider circuit for ACDET pin. As per voltage divider formula you shoud get 2.60V (19x137/866+137). You are measuring 1V at acdet pin, so either of these two resistors is likely bad. Measure both of them preferably out of circuit.
                              • stingerchamp
                                • Sep 2020
                                • 425
                                • Pakistan
                                If you read functional diagram BQ24780SRUYR you will notice even at acdet greater than 0.6 voltage your REGN 6v should generate. Check pin 24 value again at charging ic.
                                What is voltage on pc122
                                Last edited by stingerchamp; 12-10-2020, 10:17 PM. Reason: Read data sheet requirements
                                • kalilinux25
                                  • Mar 2018
                                  • 2069
                                  • ZAMBOANGA SIBUGAY
                                  I dont have any voltages sir I dont know why
                                  • PantherDave
                                    by PantherDave
                                    Hi all!
                                    05-29-2024, 02:01 PM
                                  • Tynan Dill
                                    by Tynan Dill
                                    Assuming...
                                    11-22-2024, 01:46 PM
                                  • meraklinetx
                                    Asus Z97-a power cycle, no boot no cpu voltage
                                    by meraklinetx
                                    Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                                    05-10-2023, 06:08 AM
                                  • labello
                                    Power supply Termaltake Smart Se 630w any voltage in output
                                    by labello
                                    Hello everybody I try to fix thi power supply, I have voltage in bridge rectifier, and also in the large capacitor , so I thought the problem was in the pfc but then I found all mosfet ok(tested out of the circuit so I just moved on in the low voltage and here I found a short of one of the diode rectifier. I'll replaced it already but it's completely dead, I mean any stanby voltage and the other voltage is not present. I don't have oscilloscope to understand if the chip work how can I test it? Thank you for the help 🙏
                                    09-09-2023, 12:06 PM
                                  • dicky96
                                    L4973V5.1 Power supply giving too much output voltage
                                    by dicky96
                                    Hi guys
                                    This power supply is from an FM Radio transmitter
                                    It takes an input of 28V and should output some lower voltage. When I first looked at it I found that there is a zener diode D3 directly across the V out to ground and it was short circuit.
                                    I removed the Zener, there are no markings to determine it's correct value, and I don't know what Wattage it should be either, plus it broke in half. I took a photo comparing it to a 1N914 signal diode and a smaller zener which I have (which I think are 0.5W but I am not sure) and also a resistor so maybe someone can...
                                    01-15-2021, 06:29 AM
