Sony SVF152A29M DAOHK9MB6D0 Dead
  • videomax
    • Nov 2013
    • 5
    • Portugal
    Laptop completely dead and don't react to power switch.
    +3V_WAKE, +5V_WAKE, +3VPCU present
    Checking NUVOTON NCPE985LA0DX line "NBSWON#" (power switch ) wont rise to 3v.
    After replacing EC NCPE chip the problem mantain exacly the same.
    Question. Does this chip need to be programmed ?
    Does anyone have a power up sequence for this board ?
    Any help at all ?
    • 21695
    Re: Sony SVF152A29M DAOHK9MB6D0 Dead
    Schematic https://www.badcaps.net/forum/showth...ht=DA0HK9MB6D0
    • videomax
      • Nov 2013
      • 5
      • Portugal
      I have schematics! There is no Power up sequence.
      I have struggle to identify why NBSWON# does not rise.
      Thanks anyway.
      • piernov
        • Jan 2016
        • 4437
        • France
        Confirmed it's not a power button problem?
        Did you try toflash the BIOS?
        +5V_S5 and +3V_S5 present?
        • videomax
          • Nov 2013
          • 5
          • Portugal
          Hi Piernov
          Power button checked and OK
          +5V_S5 and +3V_S5 present!
          After flashing Bios chip "NBSWON#" becomes high board starts up.
          Many Thanks for your help.
          Best regards
          • thstuff
            Sony OLED XR-77A80J - Initially dead, now 4 Flashes
            by thstuff
            A) TV initially dead
            B) On a hunch of a locked up Google OS, plugged in a USB memory stick with latest FW and plugged it in. It booted into the update screen, completed the update and restarted to Home screen.
            C) Was able to perform a Reset from Settings menu and completed out of box configuration.
            D) Ran a 4K screen saver demo for about 6 hours, then turned it off for the day. Did not notice any stripes, dead zones or other artifacts in the image.
            E) Powered back on and it now runs for a few minutes before relay clicks, screen goes blank, Main Board Red Digital Optical...
            12-26-2024, 09:10 PM
          • bohaboha
            SONY KDL-46R473A ALMOST DEAD NO STB
            by bohaboha
            Hello to everyone in this wonderful forum.
            I have this SONY LCD TV KDL_46R473a
            PSU GL5 APS350 :1-888-122- 12
            MAINBOARD FY13_EU IP-012C101-4010
            black screen ,no STB no life almost death.
            on PS all the required volts are present 394V on the main cap and those on cold side 12.41V,3.45 and 3.45 are on
            Also 3,5,and 12v are on.
            nothing happens if i disconnect the PSU from the mainboard as on Samsung because here i think the mainboard gives the signal to the ps.
            don't know what to do next all suggestions and advice are very welcome​...
            04-24-2025, 04:40 PM
          • Talyn
            Sony 55W905 dead
            by Talyn
            My Sony W905 started to turn itself off an on every few minutes and blinking 8 times red in standby. A few minutes later the tv was completely dead.
            I can only hear the click of the PSU when attaching/detaching the power cable. No standby LED.
            Any advice? Thanks!
            04-15-2024, 08:14 AM
          • mrsith
            Sony KDL-55W755C - Dead
            by mrsith
            Hello again lifesavers.
            I have a KDL-55W755c that came in dead - not even standby light going on. Tested the power supply - all correct. Tested the output pins on the Led driver board (in which the power cord plugs in) - all seemed fine.
            I got a service manual for this model and tested the DC/DC converter by checking voltages on selected components. Every voltage was present where it should be. Service manual says that in this case a "Muffin" replacement is needed. This is the moment where I got stuck as I wasn't able to Google my way through it - till this day I...
            11-28-2022, 12:42 PM
          • Carlos#2003%
            Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
            by Carlos#2003%
            Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
            02-15-2024, 07:52 PM
