Dell 1420 ELSA ,Starting problem
  • ravi_1617
    YY Solutions
    • Jan 2012
    • 345
    • India
    Hi .As Power given board starts by itself ,and consumes 0.21 and than 0.33 Amps .Turns off and on again process repeats.
    It seams some problem at charging section ,during this process when I blow some hot air at charging section board boot up fine.
    already replaced MAX8731AETI. and few surrounding components but no improvement . does any one has same board charging section please image me. seems some components missing i have followed table 2 also
  • zpi
    • Feb 2018
    • 132
    • Lithuania
    Re: Dell 1420 ELSA ,Starting problem
    If it reacts to hot air, should be bad capacitor, upload photo of area.
    • ravi_1617
      YY Solutions
      • Jan 2012
      • 345
      • India
      Thanks for your experience
      Pc15 is missing, according to circuit.
      • piernov
        • Jan 2016
        • 4435
        • France
        Does it have dGPU? If yes post picture of the die.
        • ravi_1617
          YY Solutions
          • Jan 2012
          • 345
          • India
          No it don't have dGPI
          • ravi_1617
            YY Solutions
            • Jan 2012
            • 345
            • India
            dGPU don't have
            • Bowline
              by Bowline
              06-11-2025, 10:13 AM
            • diamon
              Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
              by diamon
              I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
              Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
              Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
              Pictures of these boards:
              Dell Latitude 5520 https://www.ebay.com/itm/256052956663
              Dell Latitude 5530 https://www.ebay.com/itm/125844181534
              Dell...
              02-28-2024, 12:51 PM
            • master3112
              by master3112
              07-29-2025, 01:55 PM
            • OntarioTL
              Dell 5410 greyed out BT
              by OntarioTL
              Well I've learned something new today. Of all the Dell laptops I've come across I have never seen bluetooth greyed out, and only to learn this is during the build from Dell factory. I've tried to pull the original BIOS and fix with another dell with the same issue on the forums, however the original was not recovered from the forum upgrade so I cannot do a comparison to attempt the fix on my own.
              If someone could help me out with this unit and I'll try the next one as so far I have 2 on my desk with this issue. Thanks in advance!
              Dell Lattitude 5410
              Service Tag...
              07-25-2025, 01:28 PM
            • lalle-
              Dell G5 SE 5505 - "Invalid memory installed" after BIOS update.
              by lalle-
              Hello!
              I have a problem with a Dell G5 SE 5505 laptop that I hope someone can give me a few pointers on.
              [OK, it's not really a laptop, I'm running the motherboard on my desktop with only cooling, RAM and an M2 drive attached.]
              I had some performance issues, so I decided to update my BIOS from 1.7.0 to the latest version, 1.20.0.
              The computer restarted and the update dit not want to continue without a battery connected, even though I used dell's method of bypassing this requirement.
              I tried updating to a custom BIOS from Reddit user Satori_Nori https://www...
              08-11-2024, 02:01 PM
