Dell Inspiron 5547 BIOS Corruption
  • BinaryOperatingSystem
    • Sep 2020
    • 6
    Hi all! I am having trouble with a Dell Inspiron 5547. I tried reflashing this board and starting but was having no luck. On a whim decided to verify that the bios file was still intact and received a failed verification message. I then re-flashed it, verified that the image was intact, turned on the computer (no start), verified it again and it failed. I have tried changing the BIOS chip itself (W25Q64FWSIQ) and no luck. Right after re-flashing, the board pulls .42A (which is typical) goes to zero, and then pulls .33A and stays there. It almost seems like it wants to start, gets corrupted, restarts but cannot proceed with the corrupted image. I have tried several different ram sticks. On startup my multimeter records the Hz jumping around for a second until it settles at 11.67Hz (could be operator-error as I am unfamiliar with using this mode). Any help at all would be appreciated!! The pins on the bios chip go as follows:
    PIN 1 3.3V
    PIN 2 3.3v
    PIN 3 3.3v
    PIN 4 GRND
    PIN 5 0v
    PIN 6 0v
    PIN 7 3.3v
    PIN 8 3.3v
    • 21907
    Re: Dell Inspiron 5547 BIOS Corruption
    Where did the failed verification message come from ,the bios software ? ,what programmer are you using, did you try a good bios dump .
    • khaahk
      • Dec 2013
      • 812
      • Estonia
      If by that you mean you write bios chip, solder it to mainboard - press the power button and then turn off the machine and read the chip and verify against the file you wrote - then of course you are getting a verify fail. Bios content is changing each time the machine is turned on. Even if you get a "no start" condition, there are still things written to it. You might have a failed video card or memory or not correct bios for the machine and still get a no start condition yet the contents of bios have changed.
        • Sep 2020
        • 6
        Thanks SMDFlea and Khaahk for your responses. To answer your question SMDFlea, I got a failed verification message from Flashrom. I am using a CH341a_SPI programmer and a known good dump. What Khaahk is saying makes total sense, I am just new to motherboard repair and still learning. I will keep diagnosing, thanks again!
        • gizaha
          by gizaha
          02-13-2024, 07:18 AM
        • zenius
          by zenius
          12-08-2024, 06:13 AM
        • sahamipoor
          need bios dell Inspiron 17 7000 2-in-1 p42e
          by sahamipoor
          hi...
          i need bios of dell Inspiron 17 7000 2-in-1 p42e by chassis Jedi 15/17 cml-mb 18806-1.no display by bios issue.
          i used and flashed ( dell Inspiron 17 7591) by same chassis and worked .but TMP not detect showing. and not enabling in bios(after each reset disable again). Most importantly the booting up display and startup bios (before windows loading) is too many slow!
          i updated to latest version and try other version but not working!
          service tag: HCQ3JW2
          i need your kind....
          10-01-2025, 11:10 AM
        • mikeybass
          by mikeybass
          04-23-2025, 04:30 PM
        • GadgetsFix
          Dell Inspiron 16 5630 BIOS request
          by GadgetsFix
          I'm in need of a BIOS file for a Dell Inspiron 16 5630. Unfortunately, I don't have access to the original BIOS file as this is for a replacement BIOS chip installation.
          • Model: Dell Inspiron 16 5630
          • MainBoard Part Number: 4550SC01C004
          • Laptop Serial No: GKH3JX3
          • DP/N: 0303KM
          • QUAKE N RPL UMA CS MB
          • 213251-2
          • TMN0H$KB
          01-17-2025, 07:38 AM
