Laptop Bios Question
  • tezza192
    • Nov 2020
    • 9
    Forgive me if this is a silly question but If I have a zbook g6 laptop with a locked bios (password protected) Can I just flash the chip manually with a chip programmer with the latest bios from the manufacturer website, would that remove the password?
    Many thanks
    TC
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Laptop Bios Question
    You need to check the manufacturer's website for bios update-its likely to be a update file and not full bios. You need to make a new bios from update file and then flash it with any spi bios programmer. Very likely password will be gone. Btw, in some cases the password is not stored in main bios but some dedicated chips or kbc.
    • Bloodhoundje
      by Bloodhoundje
      03-16-2024, 03:12 PM
    • STKR123
      The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
      by STKR123
      Greetings badcaps community,
      I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
      So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
      Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
      I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
      These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
      I learned that desoldering...
      10-29-2024, 06:03 AM
    • hotcrossedbuns999
      M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
      by hotcrossedbuns999
      My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
      1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
      2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
      3. I could only locate two chips that look like bios chips. Could someone verify this
      01-03-2025, 12:32 PM
    • legendkray
      BIOS Help Regarding GM5IX7A-GM6IX7A Origin Laptop
      by legendkray
      I have OriginPC EON 15SL, however, my laptop starts and shutsdown after 1-2 second. Keyboard leds are coming on then fans spinning then it shutsdown and not turning back on unless I plug out the power cable and plug it in. I had issues with bricked BIOS then I flashed BIOS I got from the vendor to the SPI chip and still it didn’t worked because my EC firmware was newer than the BIOS I have flashed. So I wanted to try flashing the EC chip with the correct firmware that matches with the BIOS also from the vendor and it worked everything was well, and then stupid me wanted to unlock some...
      07-05-2025, 09:25 AM
    • AquaMan Ua
      Problem with PANASONIC CF53 laptop after changing BIOS settings
      by AquaMan Ua
      Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
      05-17-2025, 09:40 AM
