Α1466 (820-00165-02) No fanspin,doesnt turn on
  • kosmo
    • Sep 2014
    • 34
    • Greece
    Hello, this motherboard had a low resistance in L7520 caused of Q7520 i replaced it and its ok now, i also replaced U7501. with io cable installed (J9500) i have only in (L7560 PPDDR_S3_REG_R 3.3V) and i dont have P5VS4RS3_EN , i removed all the coills one by one to see where is the problem and when i lifted (L7430 PDDR_S3_REG_L) and removed (J9500 without io cable installed) i had voltage in (L7520 PP5V_S4RS3 5V) (L7630 P1V05S0_LL 1.0v) and ((L7560 PP5V_S4RS3 3.3V) i checked all power rails and PP1V2_S3 is missing also PP0V6_S0_DDRVTT is missing.all other is ok,i checked for short and all looks ok. also with removed coil in L7430 the one side PDDR_S3_REG_L gives 2v and PPDDR_S3_REG_R 0v i replaced U7400 and still the same.i also noticed that after long time it warms up in the spot i marked in the photo i uploaded.any ideas? :/
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: Α1466 (820-00165-02) No fanspin,doesnt turn on
    This is pretty confusing. Don't remove random components without reason.
    Voltage on PM_BATLOW_L with and without FFC DC-in cable?
    • kosmo
      • Sep 2014
      • 34
      • Greece
      hello thx for response.without ffc cable 3.32v with ffc cable 0.03v
      • piernov
        • Jan 2016
        • 4439
        • France
        Use a genuine Apple Magsafe2.
        • kosmo
          • Sep 2014
          • 34
          • Greece
          all test is with genuine charger.
          • redbaron1007
            Liquid damaged macbook A1466 fan spins, but doesn't turn on.
            by redbaron1007
            I got a tricky one today in the form of a macbook air A1466 820-00165-A that will recognize the charger and turn the light green then back to orange and the fan will spin constantly, but the system won't power on. The screen never turns on, it doesn't make the bong noise it's supposed to, and pressing the power button doesn't do anything. When I took the board out to visibly inspect it I only found one spot of corrosion on the bios IC. I pulled the chip, cleaned it and the area with IPA and put fresh solder on both and put the bios chip back on, but when I went to test it again it still does the...
            10-24-2024, 05:45 PM
          • ronaldopdias
            A1398 - 820-00138 - No display and Fan on high speed.
            by ronaldopdias
            Hi everyone.
            I need help with this Mac, please.
            No signs of liquid, no short on the board.
            It turns on, but will not display. The fan goes to high speed.
            L3095 - 0V
            L7520 PP5V_S4 - 5.05
            L7130 PPVBAT_G3H_CHGR_REG - 12.59V
            L7560 P3V3S5_LL - 3.32V
            L7630 PP1V05_S0_REG_R - 1.05V
            L7430 vPP1V35_S3RS0_CPUDDR - 1.36V
            L7870 P1V5S0_SW - 1.51V
            L7310 PPVCC_S0_CPU_PH1 - 0V
            L7320 PPVCC_S0_CPU_PH2 - 0V
            L7330 PPVCC_S0_CPU_PH3 - 0V
            I assumed CPU MOSFETs were faulty and replaced all of...
            09-06-2022, 05:58 AM
          • grimacelord
            820-4924 - No Power - Gets Green Then Orange Light
            by grimacelord
            Board had previous liquid damage. It was initially ultrasonic cleaned. Keyboard, battery, and trackpad flex cable were all replaced and it worked fine. Board is back for no power. Hoping someone can help me out here. Voltages taken with board, DCIN board, and original 85W charger only, no battery.
            PPPBUS_G3H - 12.54V
            PP3V42_G3H - 3.42V
            ALL_SYS_PWRGD - 0V (No pulse when triggering SMC_ONOFF_L )
            PM_SLP_Sx_L - Pulses when triggering SMC_ONOFF_L
            PM_RSMRST_L - 3.28V
            PM_PWRBTN_L - 3.42V
            PCH_DSWVRMEN - 3.18V
            PM_DSW_PWRGD - 3.43V
            PPVCC_S0_CPU...
            12-04-2021, 11:09 AM
          • pb1911nt
            820-00165 issues - waht can i do
            by pb1911nt
            Hello community, I have a MacBook Air 820-00165 with an i5 and 8GB Ram. The logic board doesn't want to start. I've taken some measurements but I can't really get any further.
            And please excuse me if something is spelled wrong, I have to use a translator.
            PPBUS_G3H = 8.6 V (stable)
            PP3V42_G3H = 3.44 V (stable)
            First Always/SMC signals
            SMC_RESET_L = 3.4 V (stable → SMC running)
            SMC_PM_G2_EN = pulses between 0 V ↔ 3.3 V
            PM_PWRBTN_L = pulses between 0 V ↔ 3.3 V
            PM_SLP_S5_L = pulses between 0 V ↔ 0.2 V
            09-30-2025, 12:26 PM
          • ACS-Repair
            MacBook Air Won't start up. Pulsing voltages
            by ACS-Repair
            Hello All
            I'm just starting to work on a MacBook Air 820-00165 that will not start up, I have the following measurements. Some voltages are steady while others are pulsing. There was a tiny bit of liquid spill on the board but I believe that I have cleared it up. There doesn't seem to be an obvious short on the board. The board is out and not connected to any of the normal hardware.
            STEADY VOLTAGES:
            PPBUS_G3H 8.59V
            PPBUS_S5_HS_COMPUTING_ISNS 8.59V
            PP3V3_S5 3.32V
            PP3V3_SUS 3.32
            PP3V42_G3H 3.41V
            PPVRTC_G3H 3.32
            06-20-2021, 06:01 PM
