820-00165A SMC dead after defective G3Hot supply
  • Beeldbuisje
    • Jul 2020
    • 57
    • Belgium
    The owner of this Macbook air tried to install Windows on this machine. During his work the macbook crashed, he tried to restart, but didn't come on anymore.
    3,425V G3Hot was just 2,7V. Two bad resistors in the G3Hot supply: R7095 & R7096. After that 3,42V; but no charger LED etc.
    PPBUSG3H is 8,1V, so this proofs no communication between SMC and "battery charger" U7100.
    What I checked:
    PP1V2_S5_SMC_VDDC: 1,2V
    SMC_ONOFF_L: 3,3V
    SMC_RESET_L:3,3V
    SMC_ONOFF_L:3,3V
    SMC_BC_ACOK: 3,3V
    SMBUS_SMC_5_G3_SDA: no signal measured with scope.
    No liquid damage etc.
    The only thing I can imagine is a short rise up of G3Hot. Because one of the defective resistors had a bad contact in it. Because they're used to control the G3Hot power chip, I'm afraid of a temporary too high G3hot. Not sure, it could be.
    Does somebody has another clue as changing the SMC chip? (hard to find )
    tnx
    Gert
  • bekirsalman
    • Nov 2016
    • 137
    • turkey
    Re: 820-00165A SMC dead after defective G3Hot supply
    If you shared the photo of the area where the problem is
    Electronicman
    • Beeldbuisje
      • Jul 2020
      • 57
      • Belgium
      I don't know how this can help you, but here are the pictures.
      Don't bother about the spot with dirt. It's some residue from cleaning the flux away. I already tried to reflow the SMC chip.
      It's heavier on the picture as it is in real.
      • piernov
        • Jan 2016
        • 4435
        • France
        Voltage on SMC_VDDA? SMC can easily be found on same model donor board.
        • dellxps15
          • Feb 2014
          • 1588
          • italy
          keep in mind that 3.42 volts, comes also without smc chip.
          i see flux on smc zone so was it reflowed ?
          people trend to give smc the tate of dead too often. reflowing , reballing can kill it. when pa c dont power on we need to figure out why. no just head some chip here and there.
          if u dont have green light: psu original and working ? dc-in board is ok? power on dcin pins ? u have the 3.4 volt for green light ? do u have 3.3 5 volt ? ppbus is 8.1 instead of 8.5 8.6 ? resistor across ppbug33h (10omh reisistor) and others are ok ?
          no fan spin ? nothing ?
          • piernov
            • Jan 2016
            • 4435
            • France
            No light on Magsafe, not turning or and SMC not communicating with charger IC to increase voltage to 8.4V/8.6V/12.6V (depending on the machine) usually points to the SMC not booting.
            It could be held in reset (not the case here), have a missing power rail (PP3V3_S5_SMC which is PP3V42_G3H, present here, or PP3V3_S5_SMC_VDDA which is taken from the previous rail with an inductor inbetween), have an issue with the crystal oscillator, or have an issue with the SMC itself (like liquid damage or just dead).
            • Beeldbuisje
              • Jul 2020
              • 57
              • Belgium
              @dellxps: one thing I didn't mention: also no fan spin. If there's no 5VS5, there's no possibility to have fan spin... All the rest of your questions are readable in my first post
              For beeing sure, I checked again the SMC_VDDA voltage. Present! 3,4V
              Is there an easy way to check the crystal oscillator? Probably using an oscilloscope and measuring the frequency?
              • Beeldbuisje
                • Jul 2020
                • 57
                • Belgium
                edit: measured on pin 1 & 3 of the oscillator, nothing, but nothing visible on the scope.
                • piernov
                  • Jan 2016
                  • 4435
                  • France
                  If the crystal and the resistors/caps connected to it aren't visibly damaged, then it's most likely the SMC anyway.
                  • Beeldbuisje
                    • Jul 2020
                    • 57
                    • Belgium
                    Indeed nothing to see. Even measured were possible and no defective components found.
                    Looking for a new SMC I guess. Hopefully I can find a cheap donorboard. Don't know what else will happen with this MacBook.
                    • Beeldbuisje
                      • Jul 2020
                      • 57
                      • Belgium
                      Does someone had some experiences where to order a good SMC chip for such a board.
                      It has to be taken from a donor board.
                      You can find lots of donor boards on AliExpress and Ebay, but those people aren't sure about the condition of the SMC chip.
                      No experience with ordering those chips, so if someone has a little advice...
                      • Beeldbuisje
                        • Jul 2020
                        • 57
                        • Belgium
                        Ordered a defective donorboard in China. Well working SMC chip, replaced it, machine fixed now. Thanks for the tips!
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          Defective board on aliexpress with smc working-sounds unbeleivable. You seems to be lucky. can you give the link from which store you buyed the donor board??
                          • Beeldbuisje
                            • Jul 2020
                            • 57
                            • Belgium
                            Not ordered on Aliexpress, but on Ebay.
                            see-ic was the shop.
                            He confirmed me his SMC on the donor board should be OK. And he was right :-)
                            • Andreas_de
                              Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                              by Andreas_de
                              Hello!
                              i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                              Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                              Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                              04-12-2025, 10:38 AM
                              by sam_sam_sam
                              03-31-2024, 02:12 PM
                            • kevin_allein
                              Samsung QE 75 Q 7 FGMTZG Power Supply dead
                              by kevin_allein
                              Hi, have this Samsung QE 75 Q 7 FGMTZG TV with no function. First analysis shows the power supply board is dead and fuse blown. Power Supply has the number BN94-11439A. I did short circuit test transistor and diodes and those do not appear to have shorts. I must admit I did not look at every single data sheet.
                              In the TV was some black dust residue, so probably one of the electrolytic caps blew, but they do not show short either.
                              Does anyone have schematics for that board ?
                              Any good tip, what could be the issue ?
                              02-27-2025, 12:15 PM
                            • KYBOSH
                              Eufy Floodlight Cam 2 Pro Dead. Power Supply issue...
                              by KYBOSH
                              I have a floodlight-security camera that recently died on me.
                              its hardwired to 115v po115v outlet. One evening it simply died. After some troubleshooting (ensuring it had power and ensuring the electronics were actually functional by supplying 5v via usb port) i realized the power supply must be the issue. The supply was noticably warm to the touch even though it was not powering anything.
                              Trying to understand what i was up against i went looking for others with similar issues and anyone who might have attempted a repair. While a few ppl have had the...
                              07-01-2024, 06:54 AM
