NEED HELP: difference between +1.0VS5_S2 and 1237LX
  • stingerchamp
    • Sep 2020
    • 425
    • Pakistan
    Hi
    I need help to know the difference between LX switching like 1237LX and +1.0VS5_S2, i have attached a picture to make it more clear.
    and +1.0Vs5_S2= +1.5V ?
  • stingerchamp
    • Sep 2020
    • 425
    • Pakistan
    Re: NEED HELP: difference between +1.0VS5_S2 and 1237LX
    As no one knows about the difference or want to share knowledge. Please remove this thread
    • piernov
      • Jan 2016
      • 4437
      • France
      People don't necessarily click on all threads all the time (and god knows I already spend way too much time checking new messages every single day here), and it's been only 3 days. You haven't even said what the board is and you just posted a picture of part of the boardview without linking to it (at least the board model number is in the titlebar in the screenshot, but we shouldn't have to spend time looking that up). In the meantime you could have looked up how a buck converter works and you'd have the answer. I hope you will spend as much time as we do in the future to help other people.
      1237LX is connected to high-side MOSFET source and low-side MOSFET drain, it's switching at high frequency between B+ voltage and ground to step down the B+ voltage. After the inductor it becomes +1.0VS5_S2, a smooth 1.0V rail which feeds the PCH core.
      • stingerchamp
        • Sep 2020
        • 425
        • Pakistan
        Hi thank you for the reply , yes i forgot to mention here although i have mentioned in other threads it is an HP omen 15 laptop Ax236tx and i am trying my best to self repair it. one more thing , i love to help others asap.
          by sam_sam_sam
          03-31-2024, 02:12 PM
          by sam_sam_sam
          07-01-2024, 06:34 AM
          by sam_sam_sam
          After all of...
          07-13-2024, 08:14 PM
          DVR camera recorder switching power supply capacitor failure really
          by sam_sam_sam
          These cheap non brand capacitors at it again
          Last night we had a power outage [ long drawn out trying three to come back up before going out completely ] and when I went to turn the DVR camera recorder back today no go 3 bad capacitors ( one capacitor no ESR reading on DVR board the other 3 capacitor on the power supply board over 40 ohm this is not a misprint ) on the external switching power supply and one capacitor on the DVR camera recorder board where the power supply that goes to the hard drive disk is
          Well at least I have the cameras back on line I to try the...
          01-22-2022, 06:28 PM
        • michel74
          How does this switching PS work ?
          by michel74
          Yes ! How does this switching PS works ? :-)
          I understand (not in deep, of course) the switching PS principle; typically, I'd expect to get a VCC just to "feed up" the STR or the Switching regulator, but I cannot figure how this VCC is "created" (on a TV switching PSU, I often see some cascaded resistors, but here, I believe that one of the transformer input should make the permanent VCC, but I cannot figure where )
          Thanks for your help. I already wrote some explanation of what I was having and did some measurements here ...
          11-02-2023, 12:35 PM
