NEED HELP: difference between +1.0VS5_S2 and 1237LX
  • stingerchamp
    • Sep 2020
    • 425
    • Pakistan
    Hi
    I need help to know the difference between LX switching like 1237LX and +1.0VS5_S2, i have attached a picture to make it more clear.
    and +1.0Vs5_S2= +1.5V ?
  • stingerchamp
    • Sep 2020
    • 425
    • Pakistan
    Re: NEED HELP: difference between +1.0VS5_S2 and 1237LX
    As no one knows about the difference or want to share knowledge. Please remove this thread
    • piernov
      • Jan 2016
      • 4435
      • France
      People don't necessarily click on all threads all the time (and god knows I already spend way too much time checking new messages every single day here), and it's been only 3 days. You haven't even said what the board is and you just posted a picture of part of the boardview without linking to it (at least the board model number is in the titlebar in the screenshot, but we shouldn't have to spend time looking that up). In the meantime you could have looked up how a buck converter works and you'd have the answer. I hope you will spend as much time as we do in the future to help other people.
      1237LX is connected to high-side MOSFET source and low-side MOSFET drain, it's switching at high frequency between B+ voltage and ground to step down the B+ voltage. After the inductor it becomes +1.0VS5_S2, a smooth 1.0V rail which feeds the PCH core.
      • stingerchamp
        • Sep 2020
        • 425
        • Pakistan
        Hi thank you for the reply , yes i forgot to mention here although i have mentioned in other threads it is an HP omen 15 laptop Ax236tx and i am trying my best to self repair it. one more thing , i love to help others asap.
          03-31-2024, 02:12 PM
          07-01-2024, 06:34 AM
          After all of...
          07-13-2024, 08:14 PM
          DVR camera recorder switching power supply capacitor failure really
          These cheap non brand capacitors at it again
          Last night we had a power outage [ long drawn out trying three to come back up before going out completely ] and when I went to turn the DVR camera recorder back today no go 3 bad capacitors ( one capacitor no ESR reading on DVR board the other 3 capacitor on the power supply board over 40 ohm this is not a misprint ) on the external switching power supply and one capacitor on the DVR camera recorder board where the power supply that goes to the hard drive disk is
          Well at least I have the cameras back on line I to try the...
          01-22-2022, 06:28 PM
          Used a Ring tester to troubleshoot a switching power supply that has a blowed fuse
          I found this switching power which has a blowed fuse checked diodes which were still good out of circuit checked main filtering capacitor with an ESR meter 220uf@450 volts 0.15 value which to me seem bad but maybe not but without these items not in the circuit because I have about 8 ohm on the output of the capacitors so I removed the switching power supply transformer and checked it with a ring tester and all but one winding showed good all others either showed two red lights or no lights on and one winding had all lights on which was the only one that was good
          One other check that...
          08-03-2021, 06:41 PM
