Dell LA-D071P 2 Amber 6 White
  • battery.12v
    • 123
    • NW
    Fourth Day working in this LAptop, I need some Help, Dell AAL15 LA-D071P, 2 Amber 6 White Error Code "MotherBoard or Chipset Failure"
    i tested all PCH power Rail are High and Stable ... RAM voltage is High, 3Alw 5ALw are High , Discrete Gpu is High and it warms up, NO PLTRST ...Fan Full Speed... IC Bios CLK pin is 0V ... is that ok ?
  • Techtiger
    • Oct 2014
    • 1601
    • france
    Re: Dell 2 Amber 6 White
    flash BIOS with a working bin if not find out RE432 2.2K Q2601 N-channel fet for any fault feedback
    • battery.12v
      • 123
      • NW
      RE342 is Fine 2.2K
      Q2601 is good no short
      Tried many Bios Files no one changed any results
      • Bonzas
        • 466
        • Indonesia
        Did you try bios from post #16 ?
        https://www.badcaps.net/forum/showthread.php?t=54542
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          If u have dc supply, observe consumption with ram/without ram while turning on. Is there difference in consumption??
          • GREAT_MERA
            • Jul 2021
            • 14
            • sri lanka
            Did you fix this? I got the same problem
            • mon2
              • Dec 2019
              • 13837
              Re: Dell LA-D071P 2 Amber 6 White
              See a lot of posts on this problem on the internet. What is the history of your unit? Any liquid spill? Are you using the same and official power adapter?
              Any recent storms / power surges / power brown-outs?
              • Themi
                Dell XPS 13 9310 2 amber 4 white memory failure
                by Themi
                I have this laptop a dell XPS 13 9310
                Power on is ok, stuck at dell logo flashing 2 amber and 4 white (link dell service manual) 2,4 Memory or RAM (Random-Access Memory) failure​
                I believe this is the spec from using micron tool to decode marking
                Images of the ram
                I am thinking to replace but wondering if there is a possibility to test while in circuit to find the faulty module? I am doubting there is any reasonable test possible while in circuit as most ram ICs I have tested previously, I have done while off board / removed.
                Another...
                11-24-2024, 09:06 AM
              • hcinne
                Dell G15 ryzen edition black screen 2 amber 1 white
                by hcinne
                I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the...
                07-23-2024, 07:56 AM
              • s_henya
                Dell Inspiron 3593 3 amber 1 white
                by s_henya
                Got this in today,
                no signs of life.
                found a broken charging port- after replacing it, the laptop turns on and charges the battery.
                Trying to turn it on, laptop powers up, capslock is on and not responding, no image on the screen. Indicator led is flashing with 3 amber 1 white.
                CPU and GPU are very hot, so laptop has all the required voltages.
                Cmos battery is okay ~2.9v which supposed to be okay.
                Could it be a bios problem?...
                10-14-2024, 03:10 AM
              • nodwas
                Dell g15 alien 2 amber 1 white led flases ?
                by nodwas
                LA-K454P error code 2 amber flashes and 1 white..
                blank screen . Can anyone point me in right Direction to look.
                all power rails correct voltage. no idea. where to go next
                02-22-2024, 01:42 PM
              • Bowline
                by Bowline
                06-11-2025, 10:13 AM
