Dell g15 alien 2 amber 1 white led flases ?
  • nodwas
    • May 2011
    LA-K454P error code 2 amber flashes and 1 white..
    blank screen . Can anyone point me in right Direction to look.
    all power rails correct voltage. no idea. where to go next
  • Zen Master
    • Sep 2024
    • 9
    • VN
    I am also having the same problem, did you solve it
    • Raven7032
      • Mar 2025
      • 8
      • RU
      Got same issue, described here
      https://www.badcaps.net/forum/troubl...oot-no-startup
      dont know solution for now
      • Themi
        Dell XPS 13 9310 2 amber 4 white memory failure
        by Themi
        I have this laptop a dell XPS 13 9310
        Power on is ok, stuck at dell logo flashing 2 amber and 4 white (link dell service manual) 2,4 Memory or RAM (Random-Access Memory) failure​
        I believe this is the spec from using micron tool to decode marking
        Images of the ram
        I am thinking to replace but wondering if there is a possibility to test while in circuit to find the faulty module? I am doubting there is any reasonable test possible while in circuit as most ram ICs I have tested previously, I have done while off board / removed.
        Another...
        11-24-2024, 09:06 AM
      • hcinne
        Dell G15 ryzen edition black screen 2 amber 1 white
        by hcinne
        I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the...
        07-23-2024, 07:56 AM
      • Amirnsrti
        Dell Inspiron 5567 2 amber 6 white error
        by Amirnsrti
        Hi everyone
        I have this Dell Inspiron 5567 laptop that shows 2 amber 6 white error when I try to turn it on it's fan starts to work at very high speed even though I just turned it on and laptop is cold, screen is black but it shows very dim lines for less than a second when I click on power button. I used it like 4 years and I got this error so I didn't used it for last 3 years.
        The error it gives is for motherboard chipset issue.
        I Read some topics that something is wrong with bios but I don't really know how to flash the bios using another bios file. So I really appreciate...
        07-08-2024, 10:40 PM
      • s_henya
        Dell Inspiron 3593 3 amber 1 white
        by s_henya
        Got this in today,
        no signs of life.
        found a broken charging port- after replacing it, the laptop turns on and charges the battery.
        Trying to turn it on, laptop powers up, capslock is on and not responding, no image on the screen. Indicator led is flashing with 3 amber 1 white.
        CPU and GPU are very hot, so laptop has all the required voltages.
        Cmos battery is okay ~2.9v which supposed to be okay.
        Could it be a bios problem?...
        10-14-2024, 03:10 AM
      • NConstantinou
        DELL INSPIRON P66F BLINKING AMBER 3 TIMES AND WHITE LIGHT 5 TIMES
        by NConstantinou
        I REMOVED INTERNAL BATTERIES AND I SUBSTITUTE RAM BUT STILL THE SAME.
        WHEN I PLUGIN CHAGER I DO HAVE 3.3,5 AND 1.8 V. AND ON PL700 I GET 0.27V.
        BIIOS PINS 7,8 I HAVE 3.3V
        IS THE PROBLEM ON MOTHERBOARD OR BIOS.
        08-21-2025, 03:23 AM
