HP Stream 13 enter model and serial number into BIOS
  • Alex123454321
    • Sep 2020
    Hello everyone!
    Looking for some advice please as I'm stuck. My daughter has a small laptop HP Stream 13 which she loves. Recently that laptop died (a liquid was spilled on it) and I offered to buy a new one but that laptop had some sentimental value for her so she asked me to try to fix it.
    Long story short I bought a new motherboard on Ebay and installed it (exactly the same motherboard with Intel N2840 just with 64 Gb memory instead of 32 Gb). The problem is the new motherboard came with blank model and serial numbers in BIOS (just zeros). I tried to create a DOS bootable USB stick with NbDMIfit utility on it but the problem is the laptop is not booting in DOS mode but rather in EFI shell which does not allow me to run the NbDMIfit utility. I am currently stuck and don't know what else can be done.
    How can I enter the model and serial numbers into HP Stream 13 BIOS? Any help will be greatly appreciated.
  • peste
    • 12600
    • ROMANIA
    Re: HP Stream 13 enter model and serial number into BIOS
    Originally posted by Alex123454321
    Hello everyone!
    I hope this helps
    https://www.youtube.com/watch?v=9T57ktw8n3Y
    • Alex123454321
      • Sep 2020
      Originally posted by peste
      Thank you peste, unfortunately that did not work. It only gives me an option to update SKU number but when I update the tool does not save, so after a reboot it's zeros again. Also MPM mode is always Lock, regardless of where I set it in that tool
      Any other suggestions will be greatly appreciated.
      • Alex123454321
        • Sep 2020
        I was finally able to resolve the issue - had to switch on the Legacy support in BIOS which allowed to boot in DOS mode from the USB stick. Then entered model and serial number using NBDmiFit utility. Thank you everyone!
        • Wahaz
          by Wahaz
          10-30-2023, 08:42 PM
        • jbonavita
          by jbonavita
          Some issues
          Things I tried
          04-29-2025, 09:38 PM
        • Friend33
          Changing BIOS Serial Number After Motherboard Replacement on EliteBook x360 G3
          by Friend33
          I have an EliteBook x360 G3 where I had to replace the motherboard. Everything is working fine and there are no errors during boot. However, I have the issue that the serial number in the BIOS is incorrect. When I run the DMI tool under Windows, I get an error stating that I am not in Unlocked Mode and therefore cannot make any changes. I was able to change the Asset Tag directly in the BIOS. Now I am wondering, can I simply read the BIOS chip, change the serial number with a hex editor, and write it back, or what other options do I have? The old motherboard did not work at...
          06-16-2024, 03:13 PM
        • TraJikar Mac
          [HELP] G712LWS BIOS capsule
          by TraJikar Mac
          I need someone that can capsulate one of the bios files below, and i prefer the older bios version so i can flash it using CH341A tool into the bios chip.
          The manufacturer BIOS files are bigger than the BIOSbackup1.bin files by 256KB and I don't know how to fix or recompile it.
          You can see in this link a conversation between me and other people (Starting at page 10) who tried to help me (thanks to their efforts), but i still couldn't fix it and the laptop is considered as dead until now.
          Also, I uploaded a backup file for the bios that I extracted by using CH341A...
          06-11-2025, 01:35 PM
        • mikeybass
          by mikeybass
          04-23-2025, 04:30 PM
