x1 yoga need alterntive SSM6K210FE chip
  • zomi
    • Nov 2011
    • 511
    i have a x1 yoga with trackpoint dead and the trackpad buttons not working
    Have checked the motherbaord conenctor and 3 are missing on pin one.
    traced back and found on q9201 - SSM6K210FE
    I am missing 3v on the source
    so looking to replace this and see what happens
    issue is SSM6K210FE need help with alternative ic chip
  • acedogblast
    by acedogblast
    11-02-2024, 05:13 PM
    Common SPI bios chip programming Questions and Answers
    by SMDFlea
    Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
    A: If you can`t read from it how do you expect to write to it ?.
    Q: Why is my bios chip unreadable ?.
    A: The programmer is faulty or has a worn or broken zif socket.
    The USB cable is frayed,connector pins worn or some other physical damage.
    Not enough amperage or voltage to power the programmer properly.
    Bad...
    09-02-2021, 04:40 PM
  • redbaron1007
    Looking for a way to read this bios chip. Lenovo Yoga 7 16arp8 bios chip.
    by redbaron1007
    I'm working on a lenovo yoga 7 16arp8 that had a bad charge port. When I replaced the port the laptops charge light will come on and stay on now, but when I push the power button the power light will come on for a couple seconds and then go right back out. I'm suspecting a bad bios, but when I went to read the bios to start the process of getting a new one it I found that none of my programmers will read the IC. I mainly use a T48 with Xgpro. I also have a ch341 and it's software that I use for ps5 uart and bios's, and a EZP2019+ and it's software.
    The chip is labeled MXIC MX77u2565ofz4142...
    10-02-2025, 12:51 PM
  • trepachka
    Help identifying this chip for Yoga 7 16IRL8
    by trepachka
    This chip is shorted thru. Based on what I see, it's either a 3.3V or 5V buck converter, just my guess. The markings on the chip state "S2=AB".
    A photo of the chip is attached.
    Thank you....
    06-22-2025, 11:13 PM
  • Rdd KEuns
    Lenovo X1 Yoga Gen5 Full Bios chip dump request.
    by Rdd KEuns
    Hello, My lenovo x1 yoga gen5 laptop has been unstable and sometime freezes. After downgrading the bios i was normal for a moment but when back to being unstable.
    If anyone has an working bios please share it.
    Laptop lenovo x1 yoga gen5. serial number PF-2MSZ9Q. Type number 20UC-S2410N. Motherboard model number GX4A0/GY650 NM-C881 Rev1.0. Bios chip GD25B256DYIG...
    03-21-2025, 05:49 AM
